Tolerance
Tolerance
martinhoos
Tolerance
martinhoos
Hello together,
is there a solution to change the +0,50 and -0,20 via iLogic  like:
If nw < 300 Then
Thanks in advance
Regards Martin
ekinsb
This will do it.  The sample code below is just getting the first dimension it finds on the sheet so you'll need to do something smarter.
Dim drawDoc As DrawingDocument = ThisDoc.Document
Dim drawDim As DrawingDimension
drawDim = drawDoc.ActiveSheet.DrawingDimensions.Item(1)
If drawDim.ModelValue > 5 Then
    drawDim.Tolerance.SetToDeviation(0.2, 0.1)
Else
    drawDim.Tolerance.SetToDeviation(0.15, 0.075)
Brian Ekins
Mod the Machine blog
martinhoos
Thanks Brian,
that will help me alot.
Regards Martin
