I have this old rule (linked in case I change/update it for any future reader) which does this as well as adding it to a custom iProperty:
(My rule doesn't filter by "Normal BOM state" however but this could be accomplished by combining with @chandra.shekar.g's post!)
Imports Inventor
Imports System.IO
Public Sub Main
If TypeOf ThisDoc.Document Is PartDocument Then
PartFeatureCount(ThisDoc)
Else
RunFeatureCount(ThisDoc.Document)
MessageBox.Show("Done!")
End Sub
Public Sub RunFeatureCount(ByVal oDoc as Inventor.Document)
Dim oAssy As inventor.AssemblyDocument
Dim oSubDoc as Inventor.Document
If oDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
oAssy = CType(oDoc,AssemblyDocument)
AssemblyFeatureCount(oAssy)
For Each oComp In oAssy.ReferencedDocuments
'oSubDoc = CType(oComp.Definition.Document,Document)
'MessageBox.Show(oSubDoc.File.FullFileName)
If oComp.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
'run FeatureCount and then call RunFeatureCount to recurse the assembly structure
'iLogicVb.RunExternalRule("FEATURECOUNT")
FeatureCount(oComp)
RunFeatureCount(oComp)
Else
'run FeatureCount
FeatureCount(oComp)
Next
ElseIf oDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
FeatureCount(oDoc)
End Sub
Sub FeatureCount(ByVal oDoc as Inventor.Document)
Try
Dim SaveRequired As Boolean = False
'uncomment for debugging purposes!
'MessageBox.Show(DocName)
If TypeOf oDoc Is PartDocument Then
If Not oDoc.File.FullFileName.Contains("Content") And Not oDoc.File.fullfilename.contains("FACILITY") And Not oDoc.File.fullfilename.contains("Imported Components") Then 'skip CC and FACILITY files
Dim PartDocName As String = System.IO.Path.GetFileNameWithoutExtension(oDoc.DisplayName) & ":1"
Dim oFeats as PartFeatures = oDoc.ComponentDefinition.Features
Dim oParams as Parameters = oDoc.ComponentDefinition.Parameters
Try
If Not iProperties.Value(PartDocName,"Custom", "FEATURECOUNT") = oFeats.Count Then 'or update it
SaveRequired = True
'MessageBox.Show("Feature Count for this part is: " & oFeats.Count, "FEATURECOUNT")
If Not iProperties.Value(PartDocName,"Custom","PARAMETERCOUNT") = oParams.Count Then 'or update it
SaveRequired = True
'MessageBox.Show("Parameter Count for " & oDoc.File.fullfilename &" is: " & oParams.Count, "PARAMETERCOUNT")
If SaveRequired Then
'oDoc.Save 'try to save the file.
Catch
Exit Sub
End Try
ElseIf TypeOf oDoc Is AssemblyDocument Then
Dim DocName As String = System.IO.Path.GetFileNameWithoutExtension(oDoc.DisplayName) & ":1"
Dim oFeats as Features = oDoc.ComponentDefinition.Features
Dim Occs as ComponentOccurrences = oDoc.ComponentDefinition.Occurrences
'Dim oConstraints as Constraints = oDoc.ComponentDefinition.Constraints
Try
If Not iProperties.Value(DocName,"Custom", "FEATURECOUNT") = oFeats.Count Then
SaveRequired = True
'MessageBox.Show("Feature Count for this assembly is: " & oFeats.Count, "FEATURECOUNT")
If Not iProperties.Value(DocName, "Custom", "OCCURRENCECOUNT") = Occs.Count Then
SaveRequired = True
'MessageBox.Show("Occurrence Count for " & oDoc.File.fullfilename & " is: " & Occs.Count, "OCCURRENCECOUNT")
If Not iProperties.Value(DocName, "Custom","PARAMETERCOUNT") = oParams.Count Then
iProperties.Value(DocName, "Custom", "PARAMETERCOUNT") = oParams.Count
SaveRequired = True
'MessageBox.Show("Parameter Count for this part is: " & oDoc.ComponentDefinition.Constraints.Count, "PARAMETERCOUNT")
If Not iProperties.Value(DocName, "Custom","CONSTRAINTCOUNT") = oDoc.ComponentDefinition.Constraints.Count Then
iProperties.Value(DocName,"Custom", "CONSTRAINTCOUNT") = oDoc.ComponentDefinition.Constraints.Count
SaveRequired = True
'MessageBox.Show("Constraint Count for Assembly " & DocName & " is: " & oDoc.ComponentDefinition.Constraints.Count, "CONSTRAINTCOUNT")
Catch
'creates any missing iProperties.
'oDoc.Save 'saves the assembly
Exit Sub
End Try
Catch ex As Exception
'MessageBox.Show("The error is: " & ex.Message & vbCrLf & ex.StackTrace,oDoc.DisplayName)
End Try
End Sub
Sub PartFeatureCount(ByVal oDoc)
Try
Dim oFeats as PartFeatures = oDoc.Document.ComponentDefinition.Features
Dim oParams as Parameters = oDoc.Document.ComponentDefinition.Parameters
Try
'may need to save the file when we're done, hence the boolean check
If Not iProperties.Value("Custom", "FEATURECOUNT") = oFeats.Count Then
SaveRequired = True
If Not iProperties.Value("Custom","PARAMETERCOUNT") = oParams.Count Then
SaveRequired = True
'MessageBox.Show("Parameter Count for " & oDoc.Document.File.fullfilename &" is: " & oParams.Count, "PARAMETERCOUNT")
Catch
'definitely need to save the file!
'oDoc.Close 'try to close the file - on a vaulted file this will fire the check-in dialogue.
End Try
'MessageBox.Show("The error is: " & ex.Message & vbCrLf & ex.StackTrace)
End Try
End Sub
Sub AssemblyFeatureCount(ByVal oDoc)
Try
'Dim DocName As String = oDoc.DisplayName
Try
SaveRequired = True
If Not iProperties.Value("Custom", "OCCURRENCECOUNT") = Occs.Count Then
SaveRequired = True
iProperties.Value("Custom", "PARAMETERCOUNT") = oParams.Count
SaveRequired = True
If Not iProperties.Value("Custom","CONSTRAINTCOUNT") = oDoc.ComponentDefinition.Constraints.Count Then
iProperties.Value("Custom", "CONSTRAINTCOUNT") = oDoc.ComponentDefinition.Constraints.Count
SaveRequired = True
Catch
Exit Sub
End Try
End Try
End Sub
