iLogic BOM Export Column Order
danmorick
danmorick
I am attempting to use ImportBOMCustomization to prepare the assembly BOM for automatic export.  What I need is a certain collection of columns in a certain order in Excel format.  But when I export the BOM through iLogic, the resulting .xls has the correct collection of properties but for some reason it reorders the columns alphabetically; i.e., the first column heading based on alphabetical order shows up in column A.  So for example my column headings from left to right have been reordered to "Description, File Path, Item, Part Number, Unit Quantity", which does not correspond to the order in my custom .xml.  I do not get this reordering when I import the customization .xml and export the BOM manually through Inventor.
Is there some setting I am unaware of to prevent this?
Thanks for any input.
I have the same issue with Inventor Professional 2016.
If you would do the export manually from the BOM window, it will export it in the right order. But when exporting with the VBA Macro it will change the columns order.
Is there any information Autodesk could share with us?
Horacio
Hi There,
I am trying to achieve the same also.
I have already set up my BOM in the column sequence I want and when I export manually through the application window, it exports out perfect.
However when using an iLogic driven rule to export the BOM, the columns in the output file are automatically placed in alphabetical order.
Can someone please refer us to a solution on the forum if it has already been solved as I cant seem to find it.
Thanks, Ash
Hi there everybody.
It seems this issue is common to all of us.
I found out the same issue in Inventor 2015 when exporting from a top level assembly. If I do from a normal assembly with no subassemblies, export goes fine, exactly as inventor would do by hand, but if done from the main assembly, with subassemblies, I have got the same issue you mention.
No patch up to today it seems, so no other workaround than updating to a newer version?
Kindly yours,
Jorge Hevia
MechMachineMan
Hi. Please see this other thread with a viable solution posted.
https://forums.autodesk.com/t5/inventor-customization/thisbom-export-column-order-problem/m-p/490203...
AddReference "Microsoft.Office.Interop.Excel" 'To use excel
Imports System.Windows.Forms
Imports System.IO
Imports Microsoft.Office.Interop.Excel        'To use excel
Sub Main()
	Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
	'Dim oPath As String
	'oPath = oFolderDlg
	'oFileName = oPath & "Bruce.xml"
	ExportBOM(oDoc)
End Sub
Private BOMCustomizationFile As String = "C:\CustFile.xml"
Private excelApp As Microsoft.Office.Interop.Excel.Application
Private xlws As Worksheet
Sub ExportBOM(oDoc As Document)
'File Path Creation/Processing
	'Note, the following line will cause an error if the document is not saved.
	Dim oExportPath As String = System.IO.Path.GetDirectoryName(oDoc.FullFileName) & "\BOM\"
	Dim oExportName As String = oExportPath & System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName) 'without extension'get BOM Target folder path
	If Not System.IO.Directory.Exists(oExportPath) Then: System.IO.Directory.CreateDirectory(oExportPath): End If
	If Dir(oExportName & ".xlsx") <> "" Then
		Kill (oExportName & ".xlsx")
'Inventor BOM Processing
	Dim oBOM As BOM = oDoc.ComponentDefinition.BOM
	oBOM.ImportBOMCustomization(BOMCustomizationFile)
	oBOM.StructuredViewEnabled = True
	oBOM.StructuredViewFirstLevelOnly = False
	Dim oStructuredBOMView As BOMView
	oStructuredBOMView = oBOM.BOMViews.Item("Structured")
	oStructuredBOMView.Export (oExportName & ".xlsx", kMicrosoftExcelFormat)
'Excel processing
	excelApp = CreateObject("Excel.Application")
	excelApp.Visible = True
	excelApp.DisplayAlerts = False
	wb = excelApp.Workbooks.Open(oExportName & ".xlsx")
	xlws = wb.Worksheets(1)
	Call ReorderXLBOM()
	excelApp.Columns.AutoFit
	excelApp = Nothing
End Sub
Private Sub ReorderXLBOM()
    Dim ndx As Integer
    Dim Found As Range
    Dim counter As Integer = 1
	Dim arrColOrder() As String = {"Item", "QTY", "Part Number", "Description", "Stock Number"}
    'arrColOrder = Array("Item", "QTY", "Part Number", "Description", "Stock Number")
	On Error Resume Next
    For ndx = LBound(arrColOrder) To UBound(arrColOrder)
        'Set Found = xlws.Rows("1:1").Find(arrColOrder(ndx),, LookIn:=xlValues, LookAt:=xlWhole, SearchOrder:=xlByColumns, SearchDirection:=xlNext, MatchCase:=False)
        Found = xlws.Rows("1:1").Find(arrColOrder(ndx), , -4163, 1, 2, 1, False)
        If Err.Number <> 0 Then
            MsgBox ("Error With Excel FIND function: " & Err.Number & " :: " & Err.Description & vbLf & vbLf & ndx)
            Err.Clear
        If Not Found Is Nothing Then
                If Found.Column <> counter Then
                        Found.EntireColumn.Cut
                        xlws.Columns(counter).Insert(-4161)
                        excelApp.CutCopyMode = False
                counter = counter + 1
    Next
            MsgBox ("Reorder Columns Rule Error: " & Err.Number & " :: " & Err.Description & vbLf & vbLf & ndx)
            Err.Clear
End Sub
Public Function oFolderDlg
    Dim dialog = New FolderBrowserDialog()
'    dialog.SelectedPath = Application.StartupPath
	dialog.ShowNewFolderButton = True
'	openFileDialog1.InitialDirectory
    If DialogResult.OK = dialog.ShowDialog() Then
        oPath = dialog.SelectedPath
	Else
		MsgBox("No File Selected. Aborting Rule")
		oPath = ""
	Return oPath
End Function
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
