EXPORT IDW TO DWG USING DWG ADDIN
BWMcDowell
BWMcDowell
I am using Inventor 2015 run as administrator and I keep getting the error:
Error in rule: DWG EXPORT, in document: 99999.IDW
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.ApplicationAddIns.get_ItemById(String ClientId)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
this is the code:
    ' Get the DWG translator Add-In.
    Dim DWGAddIn As TranslatorAddIn
    DWGAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3?AC2-122E-11D5-8E91-0010B541CD80}")
    'Set a reference to the active document (the document to be published).
    Dim oDocument As Document
    oDocument = ThisApplication.ActiveDocument
    Dim oContext As TranslationContext
    oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kFileBrowseIOMechanism
    ' Create a NameValueMap object
    Dim oOptions As NameValueMap
    oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium
    oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    ' Check whether the translator has 'SaveCopyAs' options
    Dim strIniFile As String
    'strIniFile = "O:\Templates\INVENTOR\EXPORT TEMPLATES\" & iProperties.Value("CUSTOM", "INI FILE")
    strinifile = "O:\TEMPLATES\INVENTOR\EXPORT TEMPLATES\6=1-0EXPORT.INI"
    ' Create the name-value that specifies the ini file to use.
    oOptions.Value("Export_Acad_IniFile") = strIniFile
    'oDataMedium.FileName = iProperties.Value("CUSTOM", "DWG PATH") & iProperties.Value("CUSTOM", "DWGNO") & ".DWG"
    oDataMedium.FileName = "O:\TEMPORARY.DWG"
    'Publish document.
    DWGAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
  Any help will be appreciated
Owner2229
Hi, to save assembly as DWG you can use simply "Save As":
Dim FN As String = "O:\TEMPORARY.DWG"
ThisDoc.Document.SaveAs(FN , True)
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
BWMcDowell
Will that use whatever ini file I specify because I have 30 different ini files that will need to be used
Owner2229
Ah, I see now, this should do it:
' Set a reference to the DWG translator add-in.
Dim oDWGAddIn As TranslatorAddIn
Dim i As Long
For i = 1 To ThisApplication.ApplicationAddIns.count
    If ThisApplication.ApplicationAddIns.Item(i). _
    ClassIdString = _
    "{C24E3AC2-122E-11D5-8E91-0010B541CD80}" Then
        oDWGAddIn = ThisApplication. _
        Exit For
Next
' Check to make sure the add-in is activated.
If Not oDWGAddIn.Activated Then
    oDWGAddIn.Activate
' Create a name-value map to supply information to the translator.
Dim oNameValueMap As NameValueMap = ThisApplication. _
Dim strIniFile As String = "O:\Templates\Inventor\Export templates\DWGExport.ini"
Call oNameValueMap.Add _
    ("Export_Acad_IniFile", strIniFile)
' Create a translation context and define
' that we want to output to a file.
Dim oContext As TranslationContext = ThisApplication.TransientObjects. _
' Define the type of output by specifying the filename.
Dim oOutputFile As DataMedium = ThisApplication. _
oOutputFile.FileName = "O:\TEMPOMARY.DWG"
' Call the SaveCopyAs method of the add-in.
Call oDWGAddIn.SaveCopyAs _
    (ThisApplication.ActiveDocument, _
          oContext, _
          oNameValueMap, _
          oOutputFile)
But the INI file muss be in the refered place or the rule will crash.
Mike
BWMcDowell
Changed my code out for your and changed out variabbles and found I had a type in a variable.
