How to programatically assign the Margin property of Drawing View
AndrewPotachits
AndrewPotachits
When creating a drawing section view, sometimes I need to adjust the margin. How can I access this option via Inventor API? I've been looking through the DrawingView and SectionDrawingView objects API help, but I didn't manage to find it. Did anyone have a chance to find/adjust it via the API? Thanks.
MechMachineMan
I would see if manipulating the Camera does anything... Otherwise, this might just be one of those things that is not exposed.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
AndrewPotachits
What camera manipulation may lead the same effect as setting certain value for Margin?
MechMachineMan
Well, quickly glancing at the API reference for the Camera object, SetExtents sounds very promising.
Justin K
Hi,   I Have the same problem with the drawing view margins and using the API... Did You Ever Figure This out.. I cant get it.
Thanks in Advance
maxim.teleguz
im also looking for this in 2020
