How to Control include/exclude state of components in Derived Assembly with code
cencinaNB2ET
Message 1 of 9
cencinaNB2ET
I have a Derived Assembly ( Part) that I need to control some occurrences to show or not from its parent Assembly.
I have this so far but I cant seem to use the DerivedAssemblyDefinition.InclusionOption nor explore the occurrences in the assembly from the part.
Any ideas?
Dim Doc_P As PartDocument = ThisDoc.Document
Dim oDoc_Def As ComponentDefinition = Doc_P.ComponentDefinition
Dim userParams As UserParameters = oDoc_Def.Parameters.UserParameters
Dim modelParams As ModelParameters = oDoc_Def.Parameters.ModelParameters
Dim userParams_A As UserParameters
Dim modelParams_A As ModelParameters
Dim iLogicAuto As Object = iLogicVb.Automation
Dim oDoc_Parent As AssemblyDocument
Dim oAsmDef As AssemblyComponentDefinition
Dim oDerAssemblyComp As DerivedAssemblyComponent
Dim oDerAssemblyCompDef As DerivedAssemblyDefinition
Dim Full_File_Name As String
Dim oDerEntity As DerivedAssemblyOccurrence For Each oDerAssemblyComp In Doc_P.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents oDerAssemblyComp.SuppressLinkToFile = False Next For Each oDerAssemblyComp In Doc_P.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents oDerAssemblyCompDef = oDerAssemblyComp.Definition Full_File_Name = oDerAssemblyComp.ReferencedDocumentDescriptor.FullDocumentName MessageBox.Show(Full_File_Name) 'MessageBox.Show(oDerAssemblyCompDef.Occurrences.Count) Dim Inclusion As DerivedComponentOptionEnum Inclusion = 27137 oDerAssemblyComp.Definition.InclusionOption = Inclusion 'For i = 1 To oDerAssemblyCompDef.Occurrences.Count 'oDerEntity = oDerAssemblyCompDef.Occurrences.Item(i) 'MessageBox.Show(oDerEntity.Name) 'Next
Next For Each oDerAssemblyComp In Doc_P.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents oDerAssemblyComp.SuppressLinkToFile = True Next
Replies (8)
Message 2 of 9
bradeneuropeArthur
with this:
oDerEntity.InclusionOption =kDerivedExcludeAll
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 9
bradeneuropeArthur
This is the code from the help file:
 Derived Parts and Assemblies API Sample
Description
This sample demonstrates the use of the API to create derived parts and assemblies.
Code Samples
VBA
This example used is a simple case of a part subtracted from a mold. To simplify setup, the program creates the parts representing the part and the mold. It then uses derived parts and assemblies to scale the part and subtract it from the mold.Public Sub MoldBaseSample()
    ' Initialize the string that defines the directory where the
    ' files will be created.
    Dim sFilePath As String
    sFilePath = "C:\Temp\"
    ' Call the functions to create the parts that represent the
    ' molded part and the mold base.
    Call CreateMoldPart(sFilePath & "MoldPart.ipt")
    Call CreateMoldBase(sFilePath & "MoldBase.ipt")
    ' Create a new part file to derive the mold part in.
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
                 ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
    ' Create a derived definition for the molded part.
    Dim oDerivedPartDef As DerivedPartUniformScaleDef
    Set oDerivedPartDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef(sFilePath & "MoldPart.ipt")
    ' Set the scale to use.
    oDerivedPartDef.ScaleFactor = 1.1
    ' We could set other options for the derived part using the derived part definition.
    ' In this case the defaults are good except for the scale which we changed.
    ' Create the derived part.
    Call oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Add(oDerivedPartDef)
    ' Save and close the part.  Uses SilentOperation to bypass the save dialog.
    ThisApplication.SilentOperation = True
    Call oPartDoc.SaveAs(sFilePath & "ScaledMoldPart.ipt", False)
    ThisApplication.SilentOperation = False
    oPartDoc.Close
    ' Create a new assembly file to put the mold base and scaled part together.
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.Documents.Add(kAssemblyDocumentObject, _
                ThisApplication.FileManager.GetTemplateFile(kAssemblyDocumentObject))
    ' Create the matrix used to define the position of the occurrences.  When a new
    ' matrix is created it is initialized to an identity matrix.  This will cause
    ' parts to be placed into the assembly in the same location that are in part space.
    Dim oMatrix As Matrix
    Set oMatrix = ThisApplication.TransientGeometry.CreateMatrix
    ' Place the mold base.
    Dim oOcc As ComponentOccurrence
    Set oOcc = oAsmDoc.ComponentDefinition.Occurrences.Add(sFilePath & "MoldBase.ipt", oMatrix)
    ' Rename the occurrence.  This sample uses the name to identify the occurrence later.
    ' This isn't the only method that could be used, but is one of the simplest.
    oOcc.Name = "Mold Base"
    ' Place the scaled part.
    Set oOcc = oAsmDoc.ComponentDefinition.Occurrences.Add(sFilePath & "ScaledMoldPart.ipt", oMatrix)
    oOcc.Name = "Mold Part"
    ' Save and close the assembly.
    Call oAsmDoc.SaveAs(sFilePath & "MoldSample.iam", False)
    oAsmDoc.Close
    ' Create a new part to derive the assembly into, subtracting the part from the mold base.
    ' Create a derived definition for the molded assembly.
    Dim oDerivedAsmDef As DerivedAssemblyDefinition
    Set oDerivedAsmDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.CreateDefinition(sFilePath & "MoldSample.iam")
    ' Set the part to be subtracted.
    oDerivedAsmDef.Occurrences.Item("Mold Part").InclusionOption = kDerivedSubtractAll
    ' Create the derived assembly.
    Call oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(oDerivedAsmDef)
End Sub
' Sub to create the part representing the molded part.
Private Sub CreateMoldPart(Filename As String)
    ' Create a new part document using the default part template.
    ' Create a new sketch on the XY base workplane.
    Dim oSketch As PlanarSketch
    Set oSketch = oPartDoc.ComponentDefinition.Sketches.Add(oPartDoc.ComponentDefinition.WorkPlanes(3))
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    ' Draw the geometry defining the shape of the part.
    Dim oPoints As ObjectCollection
    Set oPoints = ThisApplication.TransientObjects.CreateObjectCollection
    oPoints.Add oTG.CreatePoint2d(-5, 0)
    oPoints.Add oTG.CreatePoint2d(-4, 3)
    oPoints.Add oTG.CreatePoint2d(-2, 4)
    oPoints.Add oTG.CreatePoint2d(0, 3)
    oPoints.Add oTG.CreatePoint2d(3, 4)
    oPoints.Add oTG.CreatePoint2d(4, 2)
    oPoints.Add oTG.CreatePoint2d(5, 0)
    Dim oSpline As SketchSpline
    Set oSpline = oSketch.SketchSplines.Add(oPoints)
    oSpline.FitMethod = kSweetSplineFit
    Dim oLine As SketchLine
    Set oLine = oSketch.SketchLines.AddByTwoPoints(oSpline.FitPoint(1), oSpline.FitPoint(oSpline.FitPointCount))
    Dim oProfile As Profile
    Set oProfile = oSketch.Profiles.AddForSolid
    ' Create a revolved feature.
    Call oPartDoc.ComponentDefinition.Features.RevolveFeatures.AddFull(oProfile, oLine, kJoinOperation)
    ' Save and close the document.
    Call oPartDoc.SaveAs(Filename, False)
    oPartDoc.Close
End Sub
' Sub to create the part representing the mold base.
Private Sub CreateMoldBase(Filename As String)
    Call oSketch.SketchLines.AddAsTwoPointRectangle(oTG.CreatePoint2d(-6, -5), oTG.CreatePoint2d(6, 5))
    ' Create an extruded feature.
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = oPartDoc.ComponentDefinition
    Dim oExtrudeDef As ExtrudeDefinition
    Set oExtrudeDef = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kJoinOperation)
    Call oExtrudeDef.SetDistanceExtent(5, kNegativeExtentDirection)
    Call oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef)
    oPartDoc.Close
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 9
cencinaNB2ET
But That Entity is a derived assembly occurrence, meaning a part in the parent assembly right?
how can you include all on a part?
My assembly uses visibility on and off and sometimes place and delete parts.
So every time i Update the part it looses those parts there were taken in and out in the assembly.
Like the picture, i took those bolts out and then back in with code but the derived part doesn't show them any more.
Message 5 of 9
cencinaNB2ET
That code creates it. I already have it. Just need to edit it.
Message 6 of 9
cencinaNB2ET
Wouldn't this code just work and an existing Derived assembly part?
oDerAssemblyComp = Doc_P.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents(1)
Dim Visibility_Percentage As Long = 0
oDerAssemblyCompDef.SetRemoveByVisibilityOptions(kDerivedRemovePartsOnly, Visibility_Percentage, True)
Message 7 of 9
cencinaNB2ET
Ok I can see the parts in the assembly and their Derived Component Option Enum But I cant change it?
oDerEntity = oDerAssemblyCompDef.Occurrences.Item(i)'.InclusionOption
Inclusion =  oDerAssemblyCompDef.Occurrences.Item(i).InclusionOption
MessageBox.Show(oDerEntity.Name & vbCr & Inclusion)
oDerAssemblyCompDef.Occurrences.Item(i).InclusionOption = kDerivedIncludeAll
Next i
Message 8 of 9
Curtis_Waguespack
Hi @cencinaNB2ET
I wonder if there is a bug here?
If I set up a simple derived part of an assembly, and and I change one of the occurrences to be a bounding box, then i can use this code to change on or the other to be bounding or included.... but if I run it again it does not work... unless I manually change one again???
I hope this helps.
Curtis
oInput = InputRadioBox("Select one", "Bounding Boxes", "Defined", True, "ilogic")
Dim oPart As PartComponentDefinition
oPart = ThisApplication.ActiveDocument.ComponentDefinition
Dim oDerAssyDef As DerivedAssemblyDefinition
oDerAssyDef = oPart.ReferenceComponents.DerivedAssemblyComponents(1).Definition
Dim oDerAssy As DerivedAssemblyOccurrence
For Each oDerAssy In oDerAssyDef.Occurrences
	If oInOPut = True Then
		oDerAssy.InclusionOption = DerivedComponentOptionEnum.kDerivedBoundingBox
	Else
		oDerAssy.InclusionOption = DerivedComponentOptionEnum.kDerivedIncludeAll
Next
oPart.ReferenceComponents.DerivedAssemblyComponents(1).Definition = oDerAssyDef
Message 9 of 9
cencinaNB2ET
That's weird... But it works! thanks so much
