Flat or folded model
TONELLAL
TONELLAL
I'm looking for an iLogic rule or VBA code to display the folded or unfolded model of a sheet metal part.
When you have a sheet metal part with its flat model, you can double clic in the browser to activate the flat or folded model. How can I do the same thing in VBA or iLogic ?
MechMachineMan
Use programming help and search SheetMetalComponentDefinition or FlatPattern Property and get it's parent.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
philippe.leefsma
SheetMetalComponentDefinition.FlatPattern.Edit()
As suggested, check the help files for SheetMetalComponentDefinition  & FlatPattern object, for example if the sheet metal part hasn't been unfolded, theSheetMetalComponentDefinition.FlatPattern property returns Nothing, you need to invoke Unfold method.
You can check using SheetMetalComponentDefinition.HasFlatPattern.
Hope that helps,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
code your looking for is like this:
dim oPart as partdocument
oPart = thisapplication.activedocument
dim oShtCompDef as SheetMetalComponentDefinition
oShtCompDef = oPart.ComponentDefinition 'make sure oPart is a sheet metal part
If oShtCompDef.HasFlatPattern = False Then
    oShtCompDef.Unfold()
and these commands to see the folded and unfolded model
oShtCompDef.FlatPattern.ExitEdit()
oShtCompDef.FlatPattern.Edit()
that's vb.net code, in VBA you might have to use Set oPart = ... and Set oShtCompDef = .... if I remember correctly
TONELLAL
Ok, this is exactly what I was looking for.
Thanks for your help !
