Update When Done
Update When Done
ASchlaack
Update When Done
ASchlaack
I add this update code to most of my rules:
iLogicVb.UpdateWhenDone = True
Is it better to have it before or after the actual code? Example:
If ....Then
Else
'OR
If ....Then
Else
This question may sound dumb but what does this snippet actual do? Should everything update after the code is ran anyway?
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
xiaodong_liang
Autodesk Support
Autodesk Support
Hi Aaron,
The help of iLogic explains:
UpdateWhenDone
Updates the document that the rule is in, after the rule (and any rule it triggers) finishes running. This update is the same as clicking the Update button in the user interface.
normally, it locates in the last line.
