Export pack and go DXF with ilogic
Codered741
Codered741
I am trying to export all sheets of a drawing as DXF's, in a pack and go ZIP file for easy management.  I have the ini config file which works with the DWG export, but I cannot get the output to save as a .zip file.
Here is what I am working with.
' Get the DXF translator Add-In.
Dim DXFAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
 'Set a reference to the active document (the document to be published).
Dim oDocument As Document = ThisApplication.ActiveDocument
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options
If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
Dim strIniFile As String
strIniFile = "C:\dxf_export.ini"
' Create the name-value that specifies the ini file to use.
oOptions.Value("Export_Acad_IniFile") = strIniFile
'Set the destination file name
oDataMedium.FileName = "c:\temp\dxf.zip"
'Publish document.
DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
 This code exports all the sheets of a drawing if I change the file name output under "oDataMedium.FileName" to a .dxf extension, and the ini file to USE TRANSMITTAL=No.
I had to change the file extension of the ini file so i could upload it.
MechMachineMan
It looks like there is some other resources out there to guide you through working with zipping files to have it export then add to the zip manually.
https://www.dotnetperls.com/zipfile-vbnet
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
sajith_subramanian
Autodesk Support
Autodesk Support
Hi @Codered741,
In the ini file when I set "USE TRANSMITTAL=No", it outputs as a dxf. But when i set to  "USE TRANSMITTAL=Yes" , it creates a zip file.
I used the code in the API help to test:
Public Sub PublishDXF()
    Set DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
    Set oDocument = ThisApplication.ActiveDocument
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
        strIniFile = "C:\temp\DXFOut.ini"
    oDataMedium.FileName = "c:\temp\dxfout.dxf"   ' no need to change this extension to zip
    'Publish document.
    Call DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
Have you tried doing the same? Do you get different results?
Do let me know if this works for you.
Sajith
Sajith Subramanian
Autodesk Developer Network
aronmatheus
oPath = ThisDoc.Path
oFolder = oPath
oFileName = ThisDoc.FileName(False)
oDataMedium.FileName = oFolder & "\" & oFileName &".dxf"
'Publish document.
