Copying views into another sheet (iLogic or API )
ulasdeniz
Mentor Mentor
ulasdeniz
Suppoese I have series of catalogue drawings of AssemblyA.dwg and AssemblyB. dwg  that are completed. (Each set contains a lot of version.)
And I need to create an Assembly drawings called AssemblyA-B.dwg    which contains AssemblyA.dwg and AssemblyB. dwg as subassemblies. I need to create an automatik task to create the all of combination of the AssemblyA-B.dwgs without manually copying and pasting the views. The code will place  (or change in prepared template  ) the views of the AssemblyA.dwg and AssemblyB. dwg into AssemblyA-B.dwg
Do you have a solution for ilogic or API? (I logic preferred)
Ulaş Deniz
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" ( "ACCEPT AS SOLUTION" ) seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" (KUDO) ile ödüllendirin.
Youtube : https://www.youtube.com/channel/UCkJpVueGScmJvW1RIgqttSg
Balaji_Ram
Hi Ulas,
Here is an iLogic code to copy view from one sheet to a sheet in another drawing.
You may need to tweak the view index and the file path to suit your needs.
Dim oSrcDwg As DrawingDocument
oSrcDwg = ThisApplication.ActiveDocument
Dim oDestDwg As DrawingDocument
oDestDwg = ThisApplication.Documents.Open("D:\Temp\Inventor\MyProj\Axle\Test.dwg")
Dim oView As DrawingView
If oSrcDwg.ActiveSheet.DrawingViews.Count < 1 Then
    MsgBox ("No views found in the source drawing !")
    Return
oView = oSrcDwg.ActiveSheet.DrawingViews(1)
Dim oSheet As Sheet
For Each oSheet In oDestDwg.Sheets
    oSheet.Activate
    Call oView.CopyTo(oSheet)
    Exit For
Next
Call oDestDwg.Save
Call oDestDwg.Close(False)
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Jef_E
@Balaji_Ram Thanks for this example, but I would like to go a step further. How should can we handle multiple views that depend on each other?
Example:
oSrcDwg.ActiveSheet.DrawingViews(1) = base view
oSrcDwg.ActiveSheet.DrawingViews(2) = Section from base view
I would like to copy the section + the base view to my new dwg. How should I handle this?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
MechMachineMan
Either select your base view first or use command manager
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
DRoam
I would like to be able to do this, too. The copy/paste via Command Manager isn't a good solution. It's not pure-API, it's clunky, and it results in duplicates of the Views (with new Labels) rather than moving the Views themselves.
So I created an idea for this here: iLogic/API: Move or Copy multiple Drawing Views to different sheet at once.
Please consider giving it a vote.
