How to retrieve workplane constraints
keithjk
keithjk
I have a situation where I need to retrieve all component occurances that have a constraint to a particular work plane.  My code below is a start but once I get the contrstraints (in the for loop), I have no idea on how to retrieve the property of the constraint that tells me what it is constrained to.  Any ideas?
Dim occ As ComponentOccurrence
Dim Occurrences As Inventor.ComponentOccurrences = oAssemblyDocument.ComponentDefinition.Occurrences
For Each occ In Occurrences
If occ.DefinitionDocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Or _
occ.DefinitionDocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
myConstraintCount = occ.Constraints.Count
If myConstraintCount > 0 Then
For i = 1 To myConstraintCount
  'how do I get the constraint property that tells me what it is constrained to?
  Debug.Print(occ.Constraints.Item(i).Name)
Next
Next
wispoxy
by point?
Set occWp = ucs.XYPlane
Set occWp = ucs.XZPlane
Set occWp = ucs.YZPlane
keithjk
Maybe I could rephrase this question...
I need to turn off the visibility of all components that are constrained to a specific workplane.  This sounds like it should be easy but I can't figure it out.  I have a start on my code in my orignal post below.
wispoxy
@keithjk not sure about visibility, but I'll look into it.
keithjk
wisp,
I just saw your reply after I posted my 2nd response.  I will give it a try.
wispoxy
I found the UCS Create Method maybe you can specify / define it to your needs. Then you started talking about visibility, the link doesn't provide visibility though 😞
http://adndevblog.typepad.com/manufacturing/2014/07/create-ucs-constraints.html
Balaji_Ram
Hi Keith,
Will the WorkPlane.Dependents help in your case ?
The following code should list the constraints that are related to the workplane.
    Dim oObj As Object
    For Each oObj In oWP.Dependents
        If TypeOf oObj Is AssemblyConstraint Then
            Dim oAsmConstraint As AssemblyConstraint
            Set oAsmConstraint = oObj
            Debug.Print (oAsmConstraint.Name)
    Next
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
