Code (VB) for : If "value" contains "textA" then
I don't know the good expression for to say "contains"
 I tried this, but this expression this means "equal"
= "textA"
And this expression doesn't work.
= "*textA*"
Have you an idea ?
MegaJerk
The below should clear it up
Dim testString As String
testString = "This is a string!"
Dim searchTerm As String
searchTerm = "string"
' Using the 'Contains' method we can
' determine if a character / string is inside
' of a different string.
' The below will return True!
MessageBox.Show(testString.Contains(searchTerm))
' here is another example.
MessageBox.Show(testString.Contains("is"))
' here is an example of what happens when you search
' for a string that isn't inside of your searchable
' string. It returns a False if it can't find it!
MessageBox.Show(testString.Contains("MegaJerk"))
Also see :  msdn - String.Contain()
Another way to do this would be to use InStr()
' The below line creates a dialog box showing '11'
' the word 'string' starts at the 11th character slot
' inside of our testString variable.
MessageBox.Show(InStr(1,testString, searchTerm))
MessageBox.Show(InStr(1,testString, "is"))
' string. It returns a 0 if it can't find it!
MessageBox.Show(InStr(1,testString, "MegaJerk"))
Also see : msdn - InStr()
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
Thanks, I'm trying with my real property (part number).
Below original code
Dim oPartNumber As Property
Dim PartNumber As String
Set oPartNumber = oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number")
        PartNumber = CStr(oPartNumber.Value)
 If oPartNumber.Value = "contains text" Then
My test, but it doesn't work, I've an error at "PartNumber"
        searchTerm = "text"
 If oPartNumber.Value = PartNumber.Contains(searchTerm) Then
MegaJerk
It would seem that you’re using VBA, and not iLogic (which uses VB.net).
VBA does not have the method ‘String.Contains()’ and therefore cannot use it. It does however have the InStr method, so you can use that as follows.
Sub StringSearchTest()
    Dim oDoc As Document
    Set oDoc = ThisApplication.activeDocument
    Set oPartNumber = oDoc.PropertySets.Item _
    Dim oPartNumberValue As String
    oPartNumberValue = CStr(oPartNumber.value)
    searchTerm = "text"
    If InStr(1, oPartNumberValue, searchTerm) > 0 Then
        Debug.Print ("We found """ & searchTerm & """ :)")
    Else
        Debug.Print ("We didn't find """ & searchTerm & """ :(")
End Sub
GitHub
MechMachineMan
I believe Visual Basic also contains the LIKE operator. It's what I use in all of my VB.net coding.
A quick example would be:
oString Like "*" & oSearchString & "*"
This would look for the search string surrounded by any amount of any characters as it has 2 wildcars on the end.
This is probably the easiest way to accomplish the "contains" functionality.
https://msdn.microsoft.com/en-us/library/swf8kaxw.aspx
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
