Message 1 of 9
Add-in + Dockable Window
What am I missing here? It's creating the docked window, but not creating it's children.
So far all I have done is add a user control with some common controls on it and put this code in there:
Public Class UserControl1
Dim dc As UserControl1
Public Sub New(ByVal Application As Inventor.Application)
InitializeComponent()
Dim _InvApp As Inventor.Application
_InvApp = Application
Dim _ApplicationEvents As Inventor.ApplicationEvents
_ApplicationEvents = _InvApp.ApplicationEvents
Dim _UserInputEvents As Inventor.UserInputEvents
_UserInputEvents = _InvApp.CommandManager.UserInputEvents
' Add a event handlers to catch the user selection changes
AddHandler _ApplicationEvents.OnActivateDocument, AddressOf Document_Activated
AddHandler _UserInputEvents.OnSelect, AddressOf UserSelect
AddHandler _UserInputEvents.OnUnSelect, AddressOf UserUnSelect
Dim oUserInterfaceMgr As Inventor.UserInterfaceManager
oUserInterfaceMgr = _InvApp.UserInterfaceManager
Dim _Browser As Inventor.DockableWindow
_Browser = oUserInterfaceMgr.DockableWindows.Add("SampleClientId", "DDCIntName", "Ellimetal DDC")
_Browser.AddChild(CreateChildDialog())
_Browser.DockingState = Inventor.DockingStateEnum.kDockRight
_Browser.ShowTitleBar = True
_Browser.Visible = True
_Browser.Width = 220
End Sub
Public Function CreateChildDialog() As Long
If Not dc Is Nothing Then
dc.Dispose()
dc = Nothing
dc = New UserControl1(g_inventorApplication)
dc.Show()
Return dc.Handle.ToInt64()
End Function
Private Sub Document_Activated()
Throw New NotImplementedException
End Sub
Private Sub UserSelect()
End Sub
Private Sub UserUnSelect()
End Sub
End Class
As well as adding this line into the StandardAddInServer.Vb under the Activate Method:
Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
' Initialize AddIn members.
g_inventorApplication = addInSiteObject.Application
' Connect to the user-interface events to handle a ribbon reset.
m_uiEvents = g_inventorApplication.UserInterfaceManager.UserInterfaceEvents
Dim oBrowser As New UserControl1(g_inventorApplication)
I'm trying to take it one step at a time to get an idea of what I'm actually doing seeing as I have not made an add-in before.
Seems kind of overwhelming to start with all of extra lines of code in the project that I dont even need to look at, and not really having a clear idea of how it all works together...
Thanks in advance!
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
