Inventor 2017 Addin Templates
MechMachineMan
Advisor Advisor
MechMachineMan
I'm trying to get the Addin Templates, but it seems the devtools.msi isn't properly extracting/installing them?
I've tried running the command line
msiexec /i "C:\Users\Public\Documents\Autodesk\Inventor 2017\SDK\developertools.msi" /qb TARGETDIR="C:\Users\Gus\Desktop\DT"
but it keeps saying some scripts cannot be run and exiting.
Is there a way around this aside from getting the templates from someone else and manually copying them over?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
MechMachineMan
Nvm...
I had it typed wrong.
msiexec /a "C:\Users\Public\Documents\Autodesk\Inventor 2017\SDK\developertools.msi" /qb TARGETDIR="C:\Users\Gus\Desktop\DT"
And I can build the solution... So that's always good!
Justin K
Stakin
@MechMachineMan wrote:
Nvm...
I  run the "developertools.msi" in command window by using your solution,
but I can‘t find Autodesk Inventor Addin in the VS,
can you help me ?
