The online installer what you can download here: https://www.autodesk.com/products/dwg-trueview/overview, in enterprise environment is totally useless. I'd like to deploy the software with SCCM. If I run the installer, it download and extract the files under the administrator name and rights, that's why when I want to run the "Setup.exe" with different account, Windows doesn't access the path, file(s). Like this the installer not good for SCCM. Do you have a real offline installer? If yes, give me the download link. Thanks.
Solved by DarrenP. Go to Solution.
here you go:
DarrenP
