I am trying to activate my student version of MAYA on my ubuntu 14.04, These are the problems I a facing:
1. Autodesk cant connect to internet so online activation is not working.
2. When I switch to offline activation it says that a request code has been generated in some file ....RegInfo.html (attached), but no request code is there and a file path is there ...LongCode.xml .
3. In that file also there is no field of request code.
(We need to submit this request code to get the activation code , but the request code itself is not generated :/). What should I do here
What version are you using? As described by Otto, you may need to install the Poodle hotfix.
if that doesn't work, please reach out to Autodesk Licensing and Activation team using one of the following methods:
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
No , the problem is still there 😕 , Version - Ubuntu 14.04 , MAYA = 2015 SP2
I tried the above poodle fix suggested (for connecting to internet) , but still MAYA is unable to connect. I reinstalled MAYA, but again the same problem persists.
Another thing is I tried to manually install it but as stated in my question no request code is being generated (and for manual activation it seems I require that).
I tried contacting customer support for Licensing and activation two times via mail , stating my problem but as I can understand from their reply is that I need to generate request code somehow to manually activate MAYA (which seems impossible to generate from my side -- attached screenshot)
