Installation & Licensing
I cannot reinstall my Creative suite.
5 REPLIES 5
281 Views, 5 Replies
I had the creative suite for students.  I tried to copy the files to my ssd and then the windows said the original spot in which it was placed had been moved and will not work because of licensing.  I have been deleting files and downloading to find out the installation wizard saying the programs are on my computer still.  I have done this four times now and am fed up.  I keep finding all kinds of ways to go about it.  So far I searched my pc for "Autodesk" in the search bar.  I deleted all of those.  Presently I am using mr.fixit.  My OS is WIN 10.  Any smooth sailing advice would e appreciated, I am falling behind in my classes with the hours waiting for the installer to download only to tell me I can only get max sdk because everything else in the suite is already on my computer, ugh.  I apologize for the reiteration. Thank You in advance.
5 REPLIES 5
Otto
Hello Dreznon and welcome to the Autodesk community!
It looks like you need to find out more about downloading or re-downloading software, or are having issues that may be resolved by re-downloading.
For Windows users, before downloading products on Windows 10, please check that the product is compatible.
For general information about downloading or re-downloading (including eligibility), Community members with similar questions found the following article(s) useful:
Download Finder
Previous Versions of Autodesk Software
Download Methods
Find Your Eligibility for Previous Versions of Autodesk Software
Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. Community members with similar issues found the following article(s) useful:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Darin.Green
Use the Manual Uninstall link within my signature. This will walk through the process of using the Microsoft Fixit tool to remove the necessary files to reinstall.
If you need to download the software again, Download the software from the Autodesk Virtual Agent
Once there, use the Download Links option to navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, once they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
in reply to: Darin.Green
Thank you both, I have already done the mr. fixit and have waited until tonight to be by my computer to see your responses.  I will go ahead and try it now and let you know.
It looks like it will work.  The only thing is it said only 6.73 GB needed when the Autodesk sight said it was 16.35 GB.  I hope I get everything and it works!  Will post again soon.
Oh yeah Buddy!  I got it installed.  I also seen the directory for where my files were to be sent before I installed and directed it toward the ssd.  Awesomeness!  Thanks Thanks Thanks Thanks, oh yeah!
Administrator Productivity
