I had the creative suite for students. I tried to copy the files to my ssd and then the windows said the original spot in which it was placed had been moved and will not work because of licensing. I have been deleting files and downloading to find out the installation wizard saying the programs are on my computer still. I have done this four times now and am fed up. I keep finding all kinds of ways to go about it. So far I searched my pc for "Autodesk" in the search bar. I deleted all of those. Presently I am using mr.fixit. My OS is WIN 10. Any smooth sailing advice would e appreciated, I am falling behind in my classes with the hours waiting for the installer to download only to tell me I can only get max sdk because everything else in the suite is already on my computer, ugh. I apologize for the reiteration. Thank You in advance.
Solved by Darin.Green. Go to Solution.
Use the Manual Uninstall link within my signature. This will walk through the process of using the Microsoft Fixit tool to remove the necessary files to reinstall.
If you need to download the software again, Download the software from the Autodesk Virtual Agent
Once there, use the Download Links option to navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, once they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
Thank you both, I have already done the mr. fixit and have waited until tonight to be by my computer to see your responses. I will go ahead and try it now and let you know.
It looks like it will work. The only thing is it said only 6.73 GB needed when the Autodesk sight said it was 16.35 GB. I hope I get everything and it works! Will post again soon.
Oh yeah Buddy! I got it installed. I also seen the directory for where my files were to be sent before I installed and directed it toward the ssd. Awesomeness! Thanks Thanks Thanks Thanks, oh yeah!
