Sign in for AutoCAD LT 2017 keeps asking to log in as different user?
One of my staff are unable to access the AutoCAD LT software this morning. As a standalone license I thought we'd not have these issues?
Keeps asking to log in as a different user which I'm hesitant to do as we've had legal letters from autodesk regarding different users logging onto the same license/software in the past when people have moved desks in the office.
Replies (15)
Thanks for the reply Dean,
I have tried those links but I don't think this is the issue. I've had issues before with Autodesk's server/authorising lisences etc and this corrected itself in a day so I'm hoping this is just a blip. This member of staff could access the software fine yesterday so I'm really unsure what's happened this time.
That said, to have a member of staff unable to use this software for one whole day is not good at all. If this is the way licenses are to be used/logged into then this needs to be far more secure.
pendean
Community Legend
Community Legend
That's why I also suggest your log into your Subscription accounts page and start a support ticket: posting here will not tell anyone at the licensing group you are having an issue.
https://manage.autodesk.com/cep/#products-services/all
Have done this also Dean, thank you for the info.
pendean
Community Legend
Community Legend
This alert is showing up on tNotice.PNGhese forums
Emmsleys
Hi @Anonymous,
Currently we are experiencing an issue which is preventing some subscription customers from accessing their product. Our teams are working to have this issue solved as soon as possible.
I will do my best to circle back to the thread to provide any updates on this issue. Thank you for patience.
Sarah Emmsley
Technical Support Specialist
Emmsleys
Also,
Let me know if you have any difficulties logging a case. I'd be happy to help escalate your thread direct it to our Registration and Activation team.
Sarah Emmsley
crystal.r
Autodesk Support
Autodesk Support
We apologize for earlier issues with some of our Customers being unable to access their Autodesk product(s). This issue is now resolved. We appreciate your patience during this time.
Crystal Righetti
Emmsleys
HI @Anonymous,
I wanted to follow up to let you know that the issue has been resolved.
Please let me know if you are still having trouble with starting AutoCAD LT and the different user prompt.
Again, I apologize for the trouble.
Best,
Sarah Emmsley
Hi Autodesk,
One of my customer currently experience this sign-in issue with his Autocad LT 2017. May I know what is the solution to this? It says it is already resolved without specifying the steps to resolve it. Please help me out, thanks in advance.
Mark.Lancaster
@Anonymous
This is not Autodesk..  This is a peer to peer network where users help other users.  Although Autodesk does monitor these forums, it doesn't mean they will see and/or respond to your issue in a timely fashion.
First..  Is you subscription still active?
Secondly, I would recommend the following:
I stole this wording/reply from my buddy @Darin.Green, so he takes all the credit for the steps..  Smiley Wink
This should help get your application working. Assuming you have a valid serial number/contract.
Close the application
Please note, folders of C:\Programdata and C:\Users\[Username]\Appdata (listed below) are hidden folders and you may need to adjust your viewing settings.
On your computer, navigate to: ​​C:\ProgramData\Autodesk\CLM\LGS\<Product_Key>_2017.0.0.F  [<Product Key> is the product key of the Autodesk Application you have]
Delete the LGS.data file.
Navigate to C:\Users\[username]\AppData\Roaming\Autodesk\ folder
Delete the ADUT folder and it's contents
Start the application.
When you start the application, it will prompt you to choose one of the following:
Login - 30 day trial licenses
Serial Number - Standalone and Single-User activation
Network - Network License server for obtaining licenses from a machine on your network
Choose the option that matches your license.
Mark Lancaster
Hi Mark.Lancaster, thanks for your respond and information. I truly appreciate it.
I will try out the recommended solution next time I see my client. By the way is this a permanent solution from your experience? Or it will re-occur from time to time? Thanks in advance.
Mark.Lancaster
@Anonymous
This usually points to..
1.  The subscription is not longer active.
2.  The subscription was just renewed.
3.  Something is wrong with the associated Autodesk Account.
In the end this is not normal behavior.
Mark Lancaster
natasha.l
Hello @Anonymous,
If the user is the Account Administrator they need to assign the product to themselves, if they are not the Account Admin. then they need to ask the Account Admin to assign them as a "Named User". Please review the information below.
Subscriber is the User (Individual Users)
Subscriber is Account Administrator (They purchased the product & Assign Named Users)
Account Administrator Manages your Software (They Assign Named Users)
This may or may not be the issue but please double check. Keep us posted. Smiley Happy
natasha.l
Hello @Anonymous,
I wanted to check-in with you, I hope you were able to resolve the issue.
If so...
