Проблема с установкой REVIT 2024. Ошибка 4000/Problem installing REVIT 2024. Error 4000
sezenkin12
sezenkin12
Community Visitor
Community Visitor
Добрый день, такая проблема: поначалу загрузка идет как надо, затем где-то с процентов 20-30 она замедляется (40 минут до 97% устанавливалась) и ан 97% происходит откат установки и вылазит ошибка 4000. В программе todesk installation permission test выдало, что у меня отсутствуют права доступа к папкам ProgramFiles прочим. Файл приложил.
Good afternoon, this is the problem: at first the download goes as it should, then somewhere from 20-30 percent it slows down (40 minutes to 97% of the installation) and at 97% the installation rolls back and error 4000 appears. In the program todesk installation permission test it showed that I do not have access rights to the ProgramFiles other folders. The file is attached.
@sezenkin12 - moderator has edited this post to provide for translation. Please use a translator to post in English.
TravisNave
I recommend downloading Revit 2024 directly from the links on this thread:
https://forums.autodesk.com/t5/installation-licensing/2024-product-download-links/m-p/11871018/highl...
Make sure you are installing with local admin rights, UAC off, and anti-virus temporarily disabled.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
