Installation & Licensing
Message 1 of 8
443 Views, 7 Replies
Old version
I have a crispy new copy of AutoCAD LT97 that I have been carrying around for years. I want to install it now, and of course, PC hardware and operating systems have advanced some since the late '90's. I am running Windows 7 64 bit and the AutoCAD LT disk wants a 32 bit system.
Is there a way to override the requirement and go ahead and install it, then run it in compatibility mode for Windows 98?
Or better yet, will Autodesk upgrade this to a version that will run on a 64 bit OS?
Thanks.
7 REPLIES 7
Message 2 of 8
pendean
Explorer this older-versions AutoCAD forum for tips on how to try the installs:
http://forums.autodesk.com/t5/AutoCAD-R12-R13-R14-Archive/bd-p/15
You can buy newer full versions of LT anywhere, I like Amazon.com, but you are being silly if you think you qualify for an upgrade discount 🙂
Message 3 of 8
DarrenP
in reply to: pendean
no workaround to make it work on newer hardware and os
DarrenP
Message 4 of 8
software doesn't work that way
Message 5 of 8
braudpat
Hello
Just for Info (and FUN) : AutoCAD LT 2004 32 bits is running perfectly on Win Seven Pro 64 bits ...
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 6 of 8
pendean
in reply to: braudpat
Many older software install just fine for most users: for some, there is no easy cure or fix and no one seems to know why exactly.
Message 7 of 8
ks. I will try
Message 8 of 8
Emmsleys
This is an older thread and a lot has changed with Windows. If you are still trying to run older software you may want to try posting in the older AutoCAD forum boards as well.
Sarah Emmsley
Technical Support Specialist
Administrator Productivity
