Just fresh installed Maya but when i launch it it just displays the output window and insta crashes.
Tried uninstalling twice now.
Windows 10 is updated to the latest october update.
NVIDIA Drivers are updated to the latest.
GPU is 1050ti.
GPU is 1050ti.
Hi @filippasko.pasko and welcome to the community!
Are there any error reports when Maya crashes?
Also, for your 1050 our recommended driver version isn't the most recent version it is version 398.82. When you get a chance, can you please uninstall your current GPU driver and install version 398.82 which can be found here!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
All the best,
Sean Heasley
Tried rolling back NVIDIA drivers still the same,so went back to the latest because of gaming.
Maya doesnt diplay any error logs.
It displays the output window for a split second and it closes before i can get a glimpse at it.
I will try reinstalling maya one more time.
Just wanted to check in to see how things were going. Did reinstalling help at all?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
All the best,
Sean Heasley
Nope still same the issue persists.
Hmm ok. I went ahead and moved this thread to our Installation and Licensing board so one of our dedicated reps like @natasha.l can further assist you!
All the best,
Sean Heasley
All the best,
Sean Heasley
Have you tried running as administrator?
Yes i have tried running it as an administrator,
Still the same issue persists.
At what point does it crash, do you the see splash screen?
As soon as i launch the program the output console window almost instantly closes.
I cant even see what it says.
Have you tried repairing the install?
Yes and i have tried reinstalling about 4 times now.
@natasha.l Can you provide any guidance on this matter?
