Installation & Licensing
Issue with the activation of Inventor
13 REPLIES 13
Message 1 of 14
2382 Views, 13 Replies
Hello, I'm unfortunately here and I'm writing  this post because I can't activate my Student License of 3 years. One month ago I installed Inventor on my pc without any kind of problems but today when I was trying to reinstall it, and I had also problem with that because the setup pack doesn't work ( I don't know why) and I had to download every single pack ( 3 ) on my own, because I cleaned my pc completely yesterday, I found a very big issue. If I try to put my license the Process of Inventor closes without giving me a chance to activate it. I tried in different ways but everytime the process die. I tried to activate  the license online but nothing, everytime I find an issue. I have to work on project and I have now only the trial version, but it's not enough time. Can anybody help me? I'm desperate..
13 REPLIES 13
Message 2 of 14
Mark.Lancaster
@Anonymous
Welcome to the community...
What do you mean the process died when trying to activate it.  Share a screenshot of what you're trying to see when you go to activate it.  Make sure to blur out any serial # or personal information in your image.  Also to the right of your posting is a link called New: Get an Activation Code
Use that link to try to activate your application.
Mark Lancaster
Message 3 of 14
in reply to: Mark.Lancaster
Hello, thanks for your answer. So, just right now I can't give you a screen shot, I'm working with the trial on Inventor and everytime I log out I have to wait so much to rejoin and continue working. I can describe it, when you do the first log, there is a screen with join with an account, serial number and also activate with online license ( something like this, I'm italian, I use the italian version ) when I try to activate through the serial number, the main screen disappear and on the task manager the process too. Sorry If I can I'll send you the screen,.
Message 4 of 14
natasha.l
Hello @Anonymous,
Thank you for posting on the forum, I understand you are having an issue activating your student software and had to settle for installing the trial that was successful. You can try to change the license type by following the steps below.
  1. Open the program
  2. Navigate to the top Go to  (Icon) help drop down.pngdrop-down > About Autodesk > Manage License > Change License Typechange_license_type.png
  3. The program will close
  4. Open the program again
  5. Select "Enter a Serial Number"
If this process does not work for you. You can also delete the file indicated in this article and the "Let's Get Started" screen should appear.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/You-want-to-know-how-to-change-or-reset-your-licensing-on-your-2017-software.html
Please let us know how it goes. Smiley Happy
Message 5 of 14
in reply to: natasha.l
Hello, thanks for your answer, so, I tried this process many times but everytime when I click on "Enter a Serial Number" the first window closes..
Message 6 of 14
I also tried the second solution but if I go to the indicated folder nothing happens. It's empty.
Message 7 of 14
Having the same issue here!
I tryed a ton of different stuff and nothing seems to work either!
Message 8 of 14
Mark.Lancaster
@Anonymous
Are you having an issue with activating Inventor or some other Autodesk Application?  If it is Inventor, what (year) version?  Are you a student?
Mark Lancaster
Message 9 of 14
Inventor itself, when I click to put the serial number it just closes the aplication and nothing happens, exactly as this fella's problem
It's 2017 version
And yes, I'm a student, got the serial, just can't use it!
Message 10 of 14
Mark.Lancaster
@Anonymous
Try this...
I stole this wording/reply from my buddy @Darin.Green, so he takes all the credit for the steps..  Smiley Wink
This should help get your application working. Assuming you have a valid serial number/contract.
Close the application
Please note, folders of C:\Programdata and C:\Users\[Username]\Appdata (listed below) are hidden folders and you may need to adjust your viewing settings.
On your computer, navigate to: ​​C:\ProgramData\Autodesk\CLM\LGS\<Product_Key>_2017.0.0.F  [<Product Key> is the product key of the Autodesk Application you have]
Delete the LGS.data file.
Navigate to C:\Users\[username]\AppData\Roaming\Autodesk\ folder
Delete the ADUT folder and it's contents
Start the application.
When you start the application, it will prompt you to choose one of the following:
Login - 30 day trial licenses
Serial Number - Standalone and Single-User activation
Network - Network License server for obtaining licenses from a machine on your network
Choose the option that matches your license.  Students will always select serial #.
Mark Lancaster
Message 11 of 14
Already tried that mate...
The problem is not the screen with the options showing up, is that when that screen shows up and I click into "serial number" it just closes and it doesnt proceed to the "serial number screen"!
I can do that a lot of times, the result is always the same, it closes and nothing happens
Message 12 of 14
Message 13 of 14
Mark.Lancaster
@Anonymous
Thanks for sharing what resolved your issue or worked for you.  If it was me, I would come back to the forum and select your answer as a solution so others can benefit from it.  Smiley Wink
Mark Lancaster
Message 14 of 14
Thanks to everyone for the answers, so yesterday I reinstalled it and everything has gone in the right way. So I don't know what is the fix really..
Administrator Productivity
