Inventor Installation Failure
Hi
I have tried to install Inventor 2015 two times now (on windows 7). I have tried to install the program on the D-drive, but doesn't want to install it on there.
If anyone can tell me what to do then please answer.
TravisNave
Doesn't want to install there why?  Most of my engineers install to their second drive.  What error are you getting?
Autodesk Forums:
Well, it says that it is missing space on the drive even though I have
about 180 GB to spare.
TravisNave
Please understand that some parts of the installation files are necessary to be installed on the root system drive. Shortcuts, registry settings, and profile customizations are all examples of this. However, you may be able to make some system changes that will allow you to install your Autodesk product and avoid this error. Please review my KB article for more information:
http://forums.autodesk.com/t5/Installation-Licensing/Out-of-disk-space-during-installation-to-anothe...
Good Luck!
Autodesk Forums:
