I'm trying to install Autocad Architecture (via the free trial first) and once I begin installation, after a few seconds, it aborts and says "error 8." Any idea what to do?
Solved by david.lau. Go to Solution.
Anyone having install error 8 issues...
Download and install per:
1. Access the Autodesk Virtual Agent (link is in my signature) and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation.
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous
Welcome to the community..
@Anonymous wrote:
That link isn't working and neither the download in virtual agent
What's not working in the Virtual Agent... It's very rare that someone is having issues downloading the application through the Autodesk Virtual Agent. Can you tell us what you are having an issue with?
Have you followed these instructions?
Mark Lancaster
while extracting it says multiple files downloaded atleast 1 file missing and then it closes. I don't know what to do
while extracting files it gives an error atleast 1 file missing.Can you help me with this.
@Anonymous
It sounds like you are trying to extract the files before everything is downloaded.
Step #2 in my installation instructions clearly states "Do not continue until all of the parts have fully downloaded." Have you done that?
Based on your information you are either trying to run the extraction instead of saving (downloading) the files to your hard drive or you are running the extraction before all of the parts are downloaded. Get all the parts downloaded first then continue on.
Mark Lancaster
Having the same problem. I already deleted my temp files then disabled my antivirus program. But having the same error.
@Anonymous
Welcome to the community...
Are you having the install error 8 issue? If so download and install per:
Mark Lancaster
