I have several problems in the last days, both with the 2018 version that I could not install, now that I could install version 2017, this error appears and does not enter the software?
What's happening with Autodesk software? have been better.
Solved by hagen.deloss. Go to Solution.
Solved by Tassoniero. Go to Solution.
fill that out and give all the information and submit it, the thing will give you an crash reporting error number and letters if you post that here someone at autodesk will look it up and give you an answer,
make sure you have all the 3ds max lastest updates and hotfixes.
also you can go into your windows event viwer double click on windows logs and applications, look up any error or warning to do with 3ds max and double click on that eror or warning windows will give you a short description of what maybe causing it if you run that through google or post it here someone will try to help you
Hi @Tassoniero
Thanks for bring this issue to the forums! I would love to try and help out!
Three things.
I look forward to helping resolve this issue 😄
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
I am using vray 3.6, windows 7
Nvidia 660 GTX 2GB Video Card
I will try to use 3dmax again 2014, almost had no problems!
When I start windows it already appears an Autodesk APP error message!
Thanks for the additional information!
I would guess that it is some sort of hardware issue, if you aren't able to launch either 3ds Max 2017, or 2018, here is the list of recommended graphics cards for 3ds Max.
Hey @natasha.l, would you have any insight into this?
Hagen Deloss
Yes I have checked everything is OK, GTX 660 2GB
There is another flaw that has appeared to me here.
My version is 3dsmax 2017 Student
I would suggest the following:
I'm hoping we can get you back up and running in 3ds Max!
Hagen Deloss
Any ideas or questions on my previous post? It would be helpful if you had time to give an update, that way other Community Members can benefit from your process 😄
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Whilst your GPU may be on the lower end being a student license user shouldnt have any difference as only the meta data changes.
Can you give us your system spec?
That's awesome to hear! For those that don't want to translate, the above issue was resolved by renaming the Plugin folder to Plugin_BAK, as outlined in this article.
This folder can be found under C:\Program Files\Autodesk\3ds Max <version>
I would suggest re-installing the plugin causing the performance issue, and cross checking your computers system specifications to the plugins system requirements.
If you continue to have issues with any given plugin, you should contact that plugins creators 😄
Hagen Deloss
