Installation & Licensing
Identity Manager Error with Autocad LT
7 REPLIES 7
Message 1 of 8
PaulJTaylor
269 Views, 7 Replies
This is now getting rather frustrating.
I have uninstalled, installed AutoCAD LT, uninstalled and reinstalled the identity manager, allowed app through Windows Defender and still getting no further. Is this a common issue? I have worked with AutoCAD for 25 years and never had issues like this before.
Tags (1)
7 REPLIES 7
Message 2 of 8
rkmcswain
in reply to: PaulJTaylor
I presume you have seen this? Have you opened a support ticket with Autodesk support? See below.
    • Here are the various Autodesk support offerings. You may need to be logged into your Autodesk Account in order to see an accurate list of the options available to you.
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 8
PaulJTaylor
Many thanks, I have contact through e-mail but not had a reply yet also a missed call on Monday but I was out in the field!! Even though the app isn`t running I keep getting a pop up for an Autodesk Identity Manager Report.
Message 4 of 8
mdavis22569
@PaulJTaylor
Can you share a screenshot of it?
Also, are ALL of the Autodesk and AutoCAD LT updates installed?
Can you reinstall the manager if you haven't yet?
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/7zbgTemIhA3ltRs4eACL0g.html
Mike Davis
Message 5 of 8
PaulJTaylor
in reply to: mdavis22569
Hi @mdavis22569
I have installed the latest Identity Manager v.1.10.10.1. I have also added this to my Fire Wall as a file to ignore.
Message 6 of 8
mdavis22569
Oh you're getting that error
What I share daily for this  issue
Have you seen the following article about this error:
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
On this article page, there is a troubleshooting form. Have you seen this
https://autode.sk/32xqOyu
We also want to make sure all of the Autodesk updates showing in the Autodesk Desktop app are installed .. for both AutoCAD and Autodesk products (licensing)
Also:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/The-product-licens...
As of late, if it was working and this is a new issue, I've been seeing Firewall / Access issues, please verify the following are done:
Which URLs/Protocols need to be white-listed for Autodesk Subscription Licenses
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/What-U...
How to set up antivirus (AV) exclusions to improve the stability and performance of Autodesk software
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Are-there-antivirus-excl...
Mike
Mike Davis
Message 7 of 8
PaulJTaylor
Thankyou for the support. After spending hours going through the suggestions. I took a break from it to give it some thought. I have disconnected my desktop from the WiFi and connected through my mobile data and this appears to have resolved the issue. Many thanks once again.
Message 8 of 8
mdavis22569
Make sure you have access to the following then under Wifi for the future:
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/2GO1P1KDIaLATbYJwgByp6.html
Tool that can help!
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/6IFPpIksTDfsCzp1JwIH5k.html
Mike Davis
Administrator Productivity
