This is now getting rather frustrating.
I have uninstalled, installed AutoCAD LT, uninstalled and reinstalled the identity manager, allowed app through Windows Defender and still getting no further. Is this a common issue? I have worked with AutoCAD for 25 years and never had issues like this before.
Solved by mdavis22569. Go to Solution.
I presume you have seen this? Have you opened a support ticket with Autodesk support? See below.
Many thanks, I have contact through e-mail but not had a reply yet also a missed call on Monday but I was out in the field!! Even though the app isn`t running I keep getting a pop up for an Autodesk Identity Manager Report.
Can you share a screenshot of it?
Identity Manager Error with Autocad LT
Also, are ALL of the Autodesk and AutoCAD LT updates installed?
Can you reinstall the manager if you haven't yet?
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/7zbgTemIhA3ltRs4eACL0g.html
Hi @mdavis22569
I have installed the latest Identity Manager v.1.10.10.1. I have also added this to my Fire Wall as a file to ignore.
Oh you're getting that error
What I share daily for this issue
Have you seen the following article about this error:
On this article page, there is a troubleshooting form. Have you seen this
We also want to make sure all of the Autodesk updates showing in the Autodesk Desktop app are installed .. for both AutoCAD and Autodesk products (licensing)
Also:
As of late, if it was working and this is a new issue, I've been seeing Firewall / Access issues, please verify the following are done:
Which URLs/Protocols need to be white-listed for Autodesk Subscription Licenses
How to set up antivirus (AV) exclusions to improve the stability and performance of Autodesk software
Mike
Thankyou for the support. After spending hours going through the suggestions. I took a break from it to give it some thought. I have disconnected my desktop from the WiFi and connected through my mobile data and this appears to have resolved the issue. Many thanks once again.
Make sure you have access to the following then under Wifi for the future:
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/2GO1P1KDIaLATbYJwgByp6.html
Tool that can help!
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/6IFPpIksTDfsCzp1JwIH5k.html
