Installation & Licensing
I can't install revit 2021
34 REPLIES 34
Message 1 of 35
noelrojas
25644 Views, 34 Replies
I can't install Revit 2021, it gets stuck as shown in the picture.
Tags (1)
34 REPLIES 34
Message 21 of 35
Try Browser Download. Not Install Now, not Download Now, but Browser Download.
Message 22 of 35
in reply to: mdavis22569
I'm downloading 6 provided links, bit odd solution though. Fingers crossed.
Message 23 of 35
mdavis22569
My links should help .... keep us posted
Mike Davis
Message 24 of 35
Same problem here
I tried all the methods, the install finished but i cant find the program... In control panel doesnt appear, in c/programs  either
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Website | Youtube | LinkedIn
Message 25 of 35
Links helped. Thank you!
1) Download all 6 links
2) Run first EXE _001_
3) Wait, don't panic, it needs to unpack it first and then you will see Installation window (may take few mins)
4) All is installed
5) Press Finish and restart you PC
Message 26 of 35
mdavis22569
@Anonymous
Glad you're up and going!
Mike Davis
Message 27 of 35
einreza15
Hey there. After finished download all 6, should I extract all of it or just the first one?
Message 28 of 35
in reply to: einreza15
You run only the first one - Revit_2021_G1_Win_64bit_dlm_001_006.sfx.exe
Be patient, it may take minutes until you see the installation window.
Make sure you have enough free space.
Note: You don't extract them manually, it's self extracting exe, you
run only first one and the rest is done automatically.
Message 29 of 35
ashaw20UFNGR
Hello, where are these links? I've been having the same problem
Message 30 of 35
The 6-link method works. Thanks for sharing
Message 31 of 35
So I am to download and install all six of these?
then download and install from the Autodesk web page?
just making sure I have this right before I continue.
the web install wasn't working, it would get so far and then say it couldn't install at the end. even with a restart.
Message 33 of 35
thank you. I hope it works!
Message 34 of 35
Takk. Takk. Tusen takk. Løste problemet. Gjermund
Message 35 of 35
gvantine
@mdavis22569 I have been having trouble with one of my users machines with Revit 2021 and I ended up uninstalling it.  It would crash every time he tried to connect to BIM360.  So now I can't reinstall.  I've cleaned up quite a bit of his hard drive and have 130 Gb of free space.  I've tried the Autodesk app way of install and now your 6 files and both result in the same install fail.  Can you help possibly?  I can share the install log from before and after if that helps but I didn't see anything in them that gave me any indication of the problem but maybe you will?  Please let me know.  The machine is all up-to-date for windows but this has me stumped.  Any help is really appreciated.
Administrator Productivity
