Solved by RevitArkitek. Go to Solution.
Solved by noelrojas. Go to Solution.
Solved by mdavis22569. Go to Solution.
Solved by DarrenP. Go to Solution.
I'm downloading 6 provided links, bit odd solution though. Fingers crossed.
My links should help .... keep us posted
Links helped. Thank you!
1) Download all 6 links
2) Run first EXE _001_
3) Wait, don't panic, it needs to unpack it first and then you will see Installation window (may take few mins)
4) All is installed
5) Press Finish and restart you PC
@Anonymous
Glad you're up and going!
Hey there. After finished download all 6, should I extract all of it or just the first one?
So I am to download and install all six of these?
then download and install from the Autodesk web page?
just making sure I have this right before I continue.
the web install wasn't working, it would get so far and then say it couldn't install at the end. even with a restart.
Yes ...
Autodesk Revit 2021.1.1
Then click on the 001 to let it all extract
@mdavis22569 I have been having trouble with one of my users machines with Revit 2021 and I ended up uninstalling it. It would crash every time he tried to connect to BIM360. So now I can't reinstall. I've cleaned up quite a bit of his hard drive and have 130 Gb of free space. I've tried the Autodesk app way of install and now your 6 files and both result in the same install fail. Can you help possibly? I can share the install log from before and after if that helps but I didn't see anything in them that gave me any indication of the problem but maybe you will? Please let me know. The machine is all up-to-date for windows but this has me stumped. Any help is really appreciated.
