Error on Autodesk Suite 2016 installation
Hello, I get the following error when installing diferent components of AutoCAD Design Suite 2016. What can I do about it? Thank you!
2015/12/6:20:13:37 User USER-PC === Setup started on USER-PC by User ===
2015/12/6:20:13:37 User USER-PC Path_Length: 154
2015/12/6:20:13:37 User USER-PC Current Directory C:\Autodesk\ADS_Ultimate_2016_English_Win_32_64bit_WI_en-us
2015/12/6:20:13:37 User USER-PC Launch
2015/12/6:20:13:37 User USER-PC CommandLine /PK 769H1 /SN 900-55770035 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/ADS_Ultimate_2016_English_Win_32_64bit_WI_en-u...
2015/12/6:20:13:37 User USER-PC Current Directory C:\Users\User\AppData\Local\Temp\_AID170.tmp
2015/12/6:20:15:42 User USER-PC === Setup ended ===
2015/12/6:20:13:40 User USER-PC === Setup started on USER-PC by User ===
2015/12/6:20:13:40 User USER-PC Path_Length: 154
2015/12/6:20:13:40 User USER-PC Current Directory C:\Users\User\AppData\Local\Temp\_AID170.tmp
2015/12/6:20:13:40 User USER-PC Launch
2015/12/6:20:14:17 User USER-PC Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/SETUPMA...
2015/12/6:20:14:17 User USER-PC Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/SETUPMA...
2015/12/6:20:14:18 User USER-PC Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/SETUP_x...
2015/12/6:20:15:42 User USER-PC Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/SETUP_x...
2015/12/6:20:15:42 User USER-PC PageOpen LaunchDialog
2015/12/6:20:16:09 User USER-PC Install CustomCallback Info Invoking custom callback for details: [ALIAS] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\User\AppData\Local\Temp\_AID170.tmp\Setup\PrDSUI.dll
2015/12/6:20:16:09 User USER-PC Install CustomCallback Info Custom callback response: Status=3 ERROR Title= Message=Autodesk Alias Design 2016 is available for download only. URLTitle=Click here to download now URLLink="www.autodesk.com/download-alias2016_enu"
2015/12/6:20:17:24 User USER-PC PageOpen LicenseDialog
2015/12/6:20:17:24 User USER-PC PageOpen ProductInfoDialog
2015/12/6:20:17:24 User USER-PC PageOpen ProductSelectionDialog2
2015/12/6:20:18:07 User USER-PC PageOpen FullProgressDialog
2015/12/6:20:18:07 User USER-PC Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/STARTMA...
2015/12/6:20:18:07 User USER-PC Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/STARTMA...
2015/12/6:20:18:08 User USER-PC Download Play DOTNET45SP1 http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/DOTNET4...
2015/12/6:20:20:24 User USER-PC Download Complete DOTNET45SP1 http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/DOTNET4...
2015/12/6:20:20:24 User USER-PC Installing .NET Framework Runtime 4.5 SP1: "C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016\3rdParty\NET\45SP1\wcu\dotNetFramework\NDP451-KB2858728-x86-x64-AllOS-ENU.exe" /q /norestart
2015/12/6:20:24:59 User USER-PC Install .NET Framework Runtime 4.5 SP1 Succeeded
2015/12/6:20:25:02 User USER-PC Download Play VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/VCREDIS...
2015/12/6:20:25:05 User USER-PC Download Complete VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/VCREDIS...
2015/12/6:20:25:05 User USER-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2015/12/6:20:25:36 User USER-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2015/12/6:20:25:37 User USER-PC Download Play VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/VCREDIS...
2015/12/6:20:25:42 User USER-PC Download Complete VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/VCREDIS...
2015/12/6:20:25:42 User USER-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2015/12/6:20:26:09 User USER-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2015/12/6:20:26:12 User USER-PC Download Play VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/VCREDIS...
2015/12/6:20:26:33 User USER-PC Download Complete VCREDIST2012X86UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/VCREDIS...
2015/12/6:20:26:33 User USER-PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\User\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2015/12/6:20:27:27 User USER-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2015/12/6:20:27:29 User USER-PC Download Play VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/VCREDIS...
2015/12/6:20:27:52 User USER-PC Download Complete VCREDIST2012X64UPD4 http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/VCREDIS...
2015/12/6:20:27:52 User USER-PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\User\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2015/12/6:20:28:33 User USER-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2015/12/6:20:28:33 User USER-PC Download Play DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/DIRECTX...
2015/12/6:20:30:17 User USER-PC Download Complete DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/DIRECTX...
2015/12/6:20:30:17 User USER-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2015/12/6:20:31:30 User USER-PC Install DirectX Runtime Succeeded
2015/12/6:20:31:31 User USER-PC Download Play CM http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/CM.tar....
2015/12/6:20:32:20 User USER-PC Download Complete CM http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/CM.tar....
2015/12/6:20:32:20 User USER-PC Installing Autodesk® Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Design Suite Ultimate 2016" SETUP_PACKAGECODE={3E8B32D6-3A7A-418D-9475-5A4BE19D0103} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={558D694E-54C3-464E-904B-FA668D94A2D8} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/6:20:32:37 User USER-PC Install Autodesk® Material Library 2016 Succeeded
2015/12/6:20:32:38 User USER-PC Download Play CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/CMILB.t...
2015/12/6:20:33:28 User USER-PC Download Complete CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/CMILB.t...
2015/12/6:20:33:28 User USER-PC Installing Autodesk® Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Design Suite Ultimate 2016" SETUP_PACKAGECODE={3E8B32D6-3A7A-418D-9475-5A4BE19D0103} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={558D694E-54C3-464E-904B-FA668D94A2D8} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/6:20:33:39 User USER-PC Install Autodesk® Material Library 2016 - Base Image Library Succeeded
2015/12/6:20:33:39 User USER-PC Download Play CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/CMAIL.t...
2015/12/6:20:34:34 User USER-PC Download Complete CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/CMAIL.t...
2015/12/6:20:34:34 User USER-PC Installing Autodesk® Material Library 2016 - Advanced Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Design Suite Ultimate 2016" SETUP_PACKAGECODE={3E8B32D6-3A7A-418D-9475-5A4BE19D0103} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;;;" PACKAGEUPI={558D694E-54C3-464E-904B-FA668D94A2D8} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/6:20:34:38 User USER-PC Install Autodesk® Material Library 2016 - Advanced Image Library Succeeded
2015/12/6:20:34:38 User USER-PC Installing Autodesk® Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Design Suite Ultimate 2016" SETUP_PACKAGECODE={3E8B32D6-3A7A-418D-9475-5A4BE19D0103} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.5 SP1,;;;;" PACKAGEUPI={558D694E-54C3-464E-904B-FA668D94A2D8} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/6:20:34:47 User USER-PC Install Autodesk® Content Service Succeeded
2015/12/6:20:34:47 User USER-PC Installing Autodesk® Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Design Suite Ultimate 2016" SETUP_PACKAGECODE={3E8B32D6-3A7A-418D-9475-5A4BE19D0103} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={558D694E-54C3-464E-904B-FA668D94A2D8} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/6:20:34:50 User USER-PC Install Autodesk® Content Service Language Pack Succeeded
2015/12/6:20:34:51 User USER-PC Download Play ACAD http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/ACAD_x6...
2015/12/6:20:45:18 User USER-PC Download Complete ACAD http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/ACAD_x6...
2015/12/6:20:45:19 User USER-PC Installing AutoCAD 2016 Core: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AID170.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/6:20:49:24 User USER-PC Install AutoCAD 2016 Core Succeeded
2015/12/6:20:49:24 User USER-PC Download Play ACAD_LP http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/ACAD_LP...
2015/12/6:20:49:41 User USER-PC Download Complete ACAD_LP http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/ACAD_LP...
2015/12/6:20:49:42 User USER-PC Installing AutoCAD 2016 Language Core: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AID170.tmp\x64\en-us\acad\AcadLP\AcadLP-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/6:20:50:05 User USER-PC Install AutoCAD 2016 Language Core Succeeded
2015/12/6:20:50:06 User USER-PC Download Play ACAOE http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/ACAOE_x...
2015/12/6:20:50:22 User USER-PC Download Complete ACAOE http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/ACAOE_x...
2015/12/6:20:50:22 User USER-PC Installing ACA & MEP 2016 Object Enabler: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AID170.tmp\x64\ACAOE\AcaOE-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/6:20:50:27 User USER-PC Install ACA & MEP 2016 Object Enabler Succeeded
2015/12/6:20:50:27 User USER-PC Download Play ACADPV http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/ACADPV_...
2015/12/6:20:50:49 User USER-PC Download Complete ACADPV http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/ACADPV_...
2015/12/6:20:50:49 User USER-PC Installing AutoCAD 2016: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AID170.tmp\x64\ACADPRIVATE\AcadPrivate-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/6:20:50:57 User USER-PC Install AutoCAD 2016 Succeeded
2015/12/6:20:50:57 User USER-PC Download Play ACAD_MAIN http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/ACAD_MA...
2015/12/6:20:51:22 User USER-PC Download Complete ACAD_MAIN http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/ACAD_MA...
2015/12/6:20:51:23 User USER-PC Installing Autodesk® AutoCAD® 2016: TRANSFORMS="C:\Users\User\AppData\Local\Temp\_AID170.tmp\x64\en-us\acad\AcadPS\AcadPS-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/6:20:52:03 User USER-PC Install Autodesk® AutoCAD® 2016 Succeeded
2015/12/6:20:52:03 User USER-PC Installing SketchUp Import plug-in: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Design Suite Ultimate 2016" SETUP_PACKAGECODE={3E8B32D6-3A7A-418D-9475-5A4BE19D0103} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={558D694E-54C3-464E-904B-FA668D94A2D8} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/6:20:52:10 User USER-PC Install SketchUp Import plug-in Succeeded
2015/12/6:20:52:10 User USER-PC Installing FARO LS 5.3.3.38662: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Design Suite Ultimate 2016" SETUP_PACKAGECODE={3E8B32D6-3A7A-418D-9475-5A4BE19D0103} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={558D694E-54C3-464E-904B-FA668D94A2D8} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Design Suite Ultimate 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/6:20:52:26 User USER-PC Install FARO LS 5.3.3.38662 Succeeded
2015/12/6:20:52:32 User USER-PC Download Play AUTODESK_RECAP http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/AUTODES...
2015/12/6:21:01:33 User USER-PC Download Error AUTODESK_RECAP <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/AUTODES...
2015/12/6:21:01:33 User USER-PC Download Aborted AUTODESK_RECAP http://edutrial.autodesk.com/NET16SWDLD/2016/DSADV/WI/{80863249-F875-42A2-819C-34013F0E1429}/AUTODES...
2015/12/6:21:01:33 User USER-PC Install Autodesk® ReCap Failed Download Failed, Installation aborted, Result=1603
2015/12/6:21:01:36 User USER-PC Rollback FARO LS 5.3.3.38662 Succeeded
2015/12/6:21:01:40 User USER-PC Rollback SketchUp Import plug-in Succeeded
2015/12/6:21:01:56 User USER-PC Rollback Autodesk® AutoCAD® 2016 Succeeded
2015/12/6:21:02:01 User USER-PC Rollback AutoCAD 2016 Succeeded
2015/12/6:21:02:04 User USER-PC Rollback ACA & MEP 2016 Object Enabler Succeeded
2015/12/6:21:02:11 User USER-PC Rollback AutoCAD 2016 Language Core Succeeded
2015/12/6:21:03:08 User USER-PC Rollback AutoCAD 2016 Core Succeeded
2015/12/6:21:03:18 User USER-PC Rollback Autodesk® Content Service Language Pack Succeeded
2015/12/6:21:03:28 User USER-PC Rollback Autodesk® Content Service Succeeded
2015/12/6:21:03:35 User USER-PC Rollback Autodesk® Material Library 2016 - Advanced Image Library Succeeded
2015/12/6:21:04:10 User USER-PC Rollback Autodesk® Material Library 2016 - Base Image Library Succeeded
2015/12/6:21:05:00 User USER-PC Rollback Autodesk® Material Library 2016 Succeeded
2015/12/6:21:05:00 User USER-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2015/12/6:21:05:00 User USER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Installation aborted, Result=1619
2015/12/6:21:05:00 User USER-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Installation aborted, Result=1619
2015/12/6:21:05:01 User USER-PC Rollback .NET Framework Runtime 4.5 SP1 Failed Failure is ignored, Result=1619
I am also having trouble installing the PRDS 2015
2015/11/25:07:47:05 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/25:07:47:05 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/25:07:47:05 bx1tesse BR00NBKORG10660 Current Directory \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img
2015/11/25:07:47:05 bx1tesse BR00NBKORG10660 Launch
2015/11/25:07:47:05 bx1tesse BR00NBKORG10660 CommandLine /qb /I \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\IMAGEM.ini /language en-US
2015/11/25:07:47:05 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AIDBDB.tmp
2015/11/25:07:49:02 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/25:07:47:57 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/25:07:47:57 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/25:07:47:57 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AIDBDB.tmp
2015/11/25:07:47:57 bx1tesse BR00NBKORG10660 Launch
2015/11/25:07:49:04 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\bx1tesse\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2015/11/25:07:49:06 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2015/11/25:07:49:06 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\bx1tesse\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2015/11/25:07:49:07 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2015/11/25:07:49:07 bx1tesse BR00NBKORG10660 Installing DirectX Runtime: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\DirectX\DXSETUP.exe" /silent
2015/11/25:07:51:48 bx1tesse BR00NBKORG10660 Install DirectX Runtime Succeeded
2015/11/25:07:51:48 bx1tesse BR00NBKORG10660 Installing Autodesk® AutoCAD® Mechanical 2015: TRANSFORMS="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\en-us\acadm\acad.mst;\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\acadm\acad-IMAGEM.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Block Vista version Check,SSE2 Support Check,.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.5,.NET Framework Runtime 4.5 Language Pack,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,DirectX Runtime,{FF59CB23-1800-4047-B40C-E20AE7051491},Microsoft Windows Media Format 9.5 Series Runtime,{427F733F-4D6C-45BC-9324-EB743104C321},{ABE2F70B-8D94-44E9-AA04-F0DB35063D62},{A37CDB58-AAE8-0000-8C13-E0F7BACB0D5F},;;{5783F2D7-E005-0409-2102-0060B0CE6BBA},{C403E867-FCF1-432B-BCC1-8FFD40A10A6E},{84A6C8C6-0000-0464-0001-83487CD4C147},{A90DD6F8-60D2-4803-AFF6-796400E73E1B},;{C8125548-F2D5-4059-823F-1F3C5BBD9F19},{EDDEE94B-214D-4B07-9727-A3E46F3E379A},{85735431-6CD3-4B16-BEC8-95332034E53B},{9D589081-AFC2-4932-9071-AC585AC1EA83},;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/11/25:07:51:54 bx1tesse BR00NBKORG10660 Install Autodesk® AutoCAD® Mechanical 2015 Failed Installation aborted, Result=1603
2015/11/25:07:51:54 bx1tesse BR00NBKORG10660 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2015/11/25:07:51:54 bx1tesse BR00NBKORG10660 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Installation aborted, Result=1619
2015/11/25:07:51:54 bx1tesse BR00NBKORG10660 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Installation aborted, Result=1619
2015/11/25:07:52:28 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/25:12:08:37 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/25:12:08:37 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/25:12:08:37 bx1tesse BR00NBKORG10660 Current Directory \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img
2015/11/25:12:08:37 bx1tesse BR00NBKORG10660 Launch
2015/11/25:12:08:37 bx1tesse BR00NBKORG10660 CommandLine /qb /I \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\IMAGEM.ini /language en-US
2015/11/25:12:08:37 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI4A4B.tmp
2015/11/25:12:10:36 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/25:12:09:33 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/25:12:09:33 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/25:12:09:33 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI4A4B.tmp
2015/11/25:12:09:33 bx1tesse BR00NBKORG10660 Launch
2015/11/25:12:10:38 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\bx1tesse\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2015/11/25:12:10:40 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2015/11/25:12:10:40 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\bx1tesse\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2015/11/25:12:10:41 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2015/11/25:12:10:41 bx1tesse BR00NBKORG10660 Installing DirectX Runtime: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\DirectX\DXSETUP.exe" /silent
2015/11/25:12:13:40 bx1tesse BR00NBKORG10660 Install DirectX Runtime Succeeded
2015/11/25:12:13:40 bx1tesse BR00NBKORG10660 Installing Autodesk® AutoCAD® Mechanical 2015: TRANSFORMS="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\en-us\acadm\acad.mst;\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\acadm\acad-IMAGEM.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Block Vista version Check,SSE2 Support Check,.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.5,.NET Framework Runtime 4.5 Language Pack,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,DirectX Runtime,{FF59CB23-1800-4047-B40C-E20AE7051491},Microsoft Windows Media Format 9.5 Series Runtime,{427F733F-4D6C-45BC-9324-EB743104C321},{ABE2F70B-8D94-44E9-AA04-F0DB35063D62},{A37CDB58-AAE8-0000-8C13-E0F7BACB0D5F},;;{5783F2D7-E005-0409-2102-0060B0CE6BBA},{C403E867-FCF1-432B-BCC1-8FFD40A10A6E},{84A6C8C6-0000-0464-0001-83487CD4C147},{A90DD6F8-60D2-4803-AFF6-796400E73E1B},;{C8125548-F2D5-4059-823F-1F3C5BBD9F19},{EDDEE94B-214D-4B07-9727-A3E46F3E379A},{85735431-6CD3-4B16-BEC8-95332034E53B},{9D589081-AFC2-4932-9071-AC585AC1EA83},;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/11/25:12:13:47 bx1tesse BR00NBKORG10660 Install Autodesk® AutoCAD® Mechanical 2015 Failed Installation aborted, Result=1603
2015/11/25:12:13:47 bx1tesse BR00NBKORG10660 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2015/11/25:12:13:47 bx1tesse BR00NBKORG10660 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Installation aborted, Result=1619
2015/11/25:12:13:47 bx1tesse BR00NBKORG10660 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Installation aborted, Result=1619
2015/11/25:12:14:24 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/26:17:03:34 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/26:17:03:34 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/26:17:03:34 bx1tesse BR00NBKORG10660 Current Directory \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img
2015/11/26:17:03:34 bx1tesse BR00NBKORG10660 Launch
2015/11/26:17:03:34 bx1tesse BR00NBKORG10660 CommandLine /qb /I \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\IMAGEM.ini /language en-US
2015/11/26:17:03:34 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AIAFF0.tmp
2015/11/26:17:05:57 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/26:17:04:16 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/26:17:04:16 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/26:17:04:16 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AIAFF0.tmp
2015/11/26:17:04:16 bx1tesse BR00NBKORG10660 Launch
2015/11/26:17:06:00 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\bx1tesse\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2015/11/26:17:06:05 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2015/11/26:17:06:05 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\bx1tesse\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2015/11/26:17:06:09 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2015/11/26:17:06:09 bx1tesse BR00NBKORG10660 Installing DirectX Runtime: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\DirectX\DXSETUP.exe" /silent
2015/11/26:17:09:42 bx1tesse BR00NBKORG10660 Install DirectX Runtime Succeeded
2015/11/26:17:09:46 bx1tesse BR00NBKORG10660 Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\bx1tesse\AppData\Local\Temp\_AIAFF0.tmp\Media.mst"
2015/11/26:17:10:28 bx1tesse BR00NBKORG10660 Install Autodesk® Material Library 2015 Succeeded
2015/11/26:17:10:32 bx1tesse BR00NBKORG10660 Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\bx1tesse\AppData\Local\Temp\_AIAFF0.tmp\Media.mst"
2015/11/26:17:11:11 bx1tesse BR00NBKORG10660 Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2015/11/26:17:11:13 bx1tesse BR00NBKORG10660 Installing Autodesk® Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS=\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\en-us\Tools\snap\ContentService.mst;C:\Users\bx1tesse\AppData\Local\Temp\_AIAFF0.tmp\Media.mst ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.5,;;;;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/11/26:17:12:58 bx1tesse BR00NBKORG10660 Install Autodesk® Content Service Succeeded
2015/11/26:17:12:59 bx1tesse BR00NBKORG10660 Installing Autodesk® Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\bx1tesse\AppData\Local\Temp\_AIAFF0.tmp\Media.mst"
2015/11/26:17:13:09 bx1tesse BR00NBKORG10660 Install Autodesk® Content Service Language Pack Succeeded
2015/11/26:17:13:09 bx1tesse BR00NBKORG10660 Installing Autodesk® AutoCAD® Mechanical 2015: TRANSFORMS="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\en-us\acadm\acad.mst;\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\acadm\acad-IMAGEM.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Block Vista version Check,SSE2 Support Check,.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.5,.NET Framework Runtime 4.5 Language Pack,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,DirectX Runtime,{FF59CB23-1800-4047-B40C-E20AE7051491},Microsoft Windows Media Format 9.5 Series Runtime,{427F733F-4D6C-45BC-9324-EB743104C321},{ABE2F70B-8D94-44E9-AA04-F0DB35063D62},{A37CDB58-AAE8-0000-8C13-E0F7BACB0D5F},;;{5783F2D7-E005-0409-2102-0060B0CE6BBA},{C403E867-FCF1-432B-BCC1-8FFD40A10A6E},{84A6C8C6-0000-0464-0001-83487CD4C147},{A90DD6F8-60D2-4803-AFF6-796400E73E1B},;{C8125548-F2D5-4059-823F-1F3C5BBD9F19},{EDDEE94B-214D-4B07-9727-A3E46F3E379A},{85735431-6CD3-4B16-BEC8-95332034E53B},{9D589081-AFC2-4932-9071-AC585AC1EA83},;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/11/26:17:13:16 bx1tesse BR00NBKORG10660 Install Autodesk® AutoCAD® Mechanical 2015 Failed Installation aborted, Result=1603
2015/11/26:17:13:16 bx1tesse BR00NBKORG10660 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2015/11/26:17:13:17 bx1tesse BR00NBKORG10660 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Installation aborted, Result=1619
2015/11/26:17:13:17 bx1tesse BR00NBKORG10660 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Installation aborted, Result=1619
2015/11/26:17:13:54 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/27:14:44:51 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/27:14:44:51 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/27:14:44:51 bx1tesse BR00NBKORG10660 Current Directory \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img
2015/11/27:14:44:51 bx1tesse BR00NBKORG10660 Launch
2015/11/27:14:44:51 bx1tesse BR00NBKORG10660 CommandLine /qb /I \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\IMAGEM.ini /language en-US
2015/11/27:14:44:51 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AIEFC2.tmp
2015/11/27:14:46:48 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/27:14:45:40 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/27:14:45:40 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/27:14:45:40 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AIEFC2.tmp
2015/11/27:14:45:40 bx1tesse BR00NBKORG10660 Launch
2015/11/27:14:46:51 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\bx1tesse\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2015/11/27:14:46:55 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2015/11/27:14:46:55 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\bx1tesse\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2015/11/27:14:46:57 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2015/11/27:14:46:57 bx1tesse BR00NBKORG10660 Installing DirectX Runtime: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\DirectX\DXSETUP.exe" /silent
2015/11/27:14:51:17 bx1tesse BR00NBKORG10660 Install DirectX Runtime Succeeded
2015/11/27:14:51:17 bx1tesse BR00NBKORG10660 Installing Autodesk® AutoCAD® Mechanical 2015: TRANSFORMS="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\en-us\acadm\acad.mst;\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\acadm\acad-IMAGEM.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Block Vista version Check,SSE2 Support Check,.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.5,.NET Framework Runtime 4.5 Language Pack,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,DirectX Runtime,{FF59CB23-1800-4047-B40C-E20AE7051491},Microsoft Windows Media Format 9.5 Series Runtime,{427F733F-4D6C-45BC-9324-EB743104C321},{ABE2F70B-8D94-44E9-AA04-F0DB35063D62},{A37CDB58-AAE8-0000-8C13-E0F7BACB0D5F},;;{5783F2D7-E005-0409-2102-0060B0CE6BBA},{C403E867-FCF1-432B-BCC1-8FFD40A10A6E},{84A6C8C6-0000-0464-0001-83487CD4C147},{A90DD6F8-60D2-4803-AFF6-796400E73E1B},;{C8125548-F2D5-4059-823F-1F3C5BBD9F19},{EDDEE94B-214D-4B07-9727-A3E46F3E379A},{85735431-6CD3-4B16-BEC8-95332034E53B},{9D589081-AFC2-4932-9071-AC585AC1EA83},;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/11/27:14:51:24 bx1tesse BR00NBKORG10660 Install Autodesk® AutoCAD® Mechanical 2015 Failed Installation aborted, Result=1603
2015/11/27:14:51:25 bx1tesse BR00NBKORG10660 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2015/11/27:14:51:25 bx1tesse BR00NBKORG10660 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Installation aborted, Result=1619
2015/11/27:14:51:25 bx1tesse BR00NBKORG10660 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Installation aborted, Result=1619
2015/11/27:14:52:01 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/27:15:10:32 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/27:15:10:32 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/27:15:10:32 bx1tesse BR00NBKORG10660 Current Directory \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img
2015/11/27:15:10:32 bx1tesse BR00NBKORG10660 Launch
2015/11/27:15:10:32 bx1tesse BR00NBKORG10660 CommandLine /qb /I \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\IMAGEM.ini /language en-US
2015/11/27:15:10:32 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI3A41.tmp
2015/11/27:15:12:26 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/27:15:11:22 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/27:15:11:22 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/27:15:11:22 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI3A41.tmp
2015/11/27:15:11:22 bx1tesse BR00NBKORG10660 Launch
2015/11/27:15:12:29 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\bx1tesse\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2015/11/27:15:12:45 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2015/11/27:15:12:45 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\bx1tesse\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2015/11/27:15:12:48 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2015/11/27:15:12:48 bx1tesse BR00NBKORG10660 Installing DirectX Runtime: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\DirectX\DXSETUP.exe" /silent
2015/11/27:15:16:45 bx1tesse BR00NBKORG10660 Install DirectX Runtime Succeeded
2015/11/27:15:16:45 bx1tesse BR00NBKORG10660 Installing Autodesk® AutoCAD® Mechanical 2015: TRANSFORMS="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\en-us\acadm\acad.mst;\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\acadm\acad-IMAGEM.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Block Vista version Check,SSE2 Support Check,.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.5,.NET Framework Runtime 4.5 Language Pack,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,DirectX Runtime,{FF59CB23-1800-4047-B40C-E20AE7051491},Microsoft Windows Media Format 9.5 Series Runtime,{427F733F-4D6C-45BC-9324-EB743104C321},{ABE2F70B-8D94-44E9-AA04-F0DB35063D62},{A37CDB58-AAE8-0000-8C13-E0F7BACB0D5F},;;{5783F2D7-E005-0409-2102-0060B0CE6BBA},{C403E867-FCF1-432B-BCC1-8FFD40A10A6E},{84A6C8C6-0000-0464-0001-83487CD4C147},{A90DD6F8-60D2-4803-AFF6-796400E73E1B},;{C8125548-F2D5-4059-823F-1F3C5BBD9F19},{EDDEE94B-214D-4B07-9727-A3E46F3E379A},{85735431-6CD3-4B16-BEC8-95332034E53B},{9D589081-AFC2-4932-9071-AC585AC1EA83},;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/11/27:15:16:55 bx1tesse BR00NBKORG10660 Install Autodesk® AutoCAD® Mechanical 2015 Failed Installation aborted, Result=1603
2015/11/27:15:16:55 bx1tesse BR00NBKORG10660 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2015/11/27:15:16:55 bx1tesse BR00NBKORG10660 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Installation aborted, Result=1619
2015/11/27:15:16:55 bx1tesse BR00NBKORG10660 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Installation aborted, Result=1619
2015/11/27:15:17:31 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/27:15:24:07 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/27:15:24:07 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/27:15:24:07 bx1tesse BR00NBKORG10660 Current Directory \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img
2015/11/27:15:24:07 bx1tesse BR00NBKORG10660 Launch
2015/11/27:15:24:07 bx1tesse BR00NBKORG10660 CommandLine /qb /I \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\IMAGEM.ini /language en-US
2015/11/27:15:24:07 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AIA591.tmp
2015/11/27:15:28:11 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/27:15:26:25 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/27:15:26:25 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/27:15:26:25 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AIA591.tmp
2015/11/27:15:26:25 bx1tesse BR00NBKORG10660 Launch
2015/11/27:15:28:13 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\bx1tesse\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2015/11/27:15:28:19 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2015/11/27:15:28:19 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\bx1tesse\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2015/11/27:15:28:23 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2015/11/27:15:28:23 bx1tesse BR00NBKORG10660 Installing DirectX Runtime: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\DirectX\DXSETUP.exe" /silent
2015/11/27:15:32:20 bx1tesse BR00NBKORG10660 Install DirectX Runtime Succeeded
2015/11/27:15:32:20 bx1tesse BR00NBKORG10660 Installing Autodesk® AutoCAD® Mechanical 2015: TRANSFORMS="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\en-us\acadm\acad.mst;\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\acadm\acad-IMAGEM.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Block Vista version Check,SSE2 Support Check,.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.5,.NET Framework Runtime 4.5 Language Pack,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,DirectX Runtime,{FF59CB23-1800-4047-B40C-E20AE7051491},Microsoft Windows Media Format 9.5 Series Runtime,{427F733F-4D6C-45BC-9324-EB743104C321},{ABE2F70B-8D94-44E9-AA04-F0DB35063D62},{A37CDB58-AAE8-0000-8C13-E0F7BACB0D5F},;;{5783F2D7-E005-0409-2102-0060B0CE6BBA},{C403E867-FCF1-432B-BCC1-8FFD40A10A6E},{84A6C8C6-0000-0464-0001-83487CD4C147},{A90DD6F8-60D2-4803-AFF6-796400E73E1B},;{C8125548-F2D5-4059-823F-1F3C5BBD9F19},{EDDEE94B-214D-4B07-9727-A3E46F3E379A},{85735431-6CD3-4B16-BEC8-95332034E53B},{9D589081-AFC2-4932-9071-AC585AC1EA83},;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/11/27:15:32:30 bx1tesse BR00NBKORG10660 Install Autodesk® AutoCAD® Mechanical 2015 Failed Installation aborted, Result=1603
2015/11/27:15:32:30 bx1tesse BR00NBKORG10660 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2015/11/27:15:32:30 bx1tesse BR00NBKORG10660 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Installation aborted, Result=1619
2015/11/27:15:32:31 bx1tesse BR00NBKORG10660 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Installation aborted, Result=1619
2015/11/27:15:33:11 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/27:15:52:01 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/27:15:52:01 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/27:15:52:01 bx1tesse BR00NBKORG10660 Current Directory \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img
2015/11/27:15:52:01 bx1tesse BR00NBKORG10660 Launch
2015/11/27:15:52:01 bx1tesse BR00NBKORG10660 CommandLine /qb /I \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\IMAGEM.ini /language en-US
2015/11/27:15:52:01 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI36C8.tmp
2015/11/27:15:53:58 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/27:15:52:49 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/27:15:52:49 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/27:15:52:49 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI36C8.tmp
2015/11/27:15:52:49 bx1tesse BR00NBKORG10660 Launch
2015/11/27:15:54:00 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2015/11/27:15:54:14 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2015/11/27:15:54:14 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2015/11/27:15:54:30 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2015/11/27:15:54:30 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\bx1tesse\AppData\Local\Temp\vcredist_x86_2010.log
2015/11/27:15:54:52 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2015/11/27:15:54:52 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\bx1tesse\AppData\Local\Temp\vcredist_x64_2010.log
2015/11/27:15:55:17 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2015/11/27:15:55:17 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\bx1tesse\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2015/11/27:15:55:39 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2015/11/27:15:55:39 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\bx1tesse\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2015/11/27:15:56:02 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2015/11/27:15:56:02 bx1tesse BR00NBKORG10660 Installing DirectX Runtime: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\DirectX\DXSETUP.exe" /silent
2015/11/27:16:00:46 bx1tesse BR00NBKORG10660 Install DirectX Runtime Succeeded
2015/11/27:16:00:51 bx1tesse BR00NBKORG10660 Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\bx1tesse\AppData\Local\Temp\_AI36C8.tmp\Media.mst"
2015/11/27:16:01:42 bx1tesse BR00NBKORG10660 Install Autodesk® Material Library 2015 Succeeded
2015/11/27:16:01:46 bx1tesse BR00NBKORG10660 Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\bx1tesse\AppData\Local\Temp\_AI36C8.tmp\Media.mst"
2015/11/27:16:02:30 bx1tesse BR00NBKORG10660 Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2015/11/27:16:02:30 bx1tesse BR00NBKORG10660 Installing Autodesk® AutoCAD® Mechanical 2015: TRANSFORMS="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\en-us\acadm\acad.mst;\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\acadm\acad-IMAGEM.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Block Vista version Check,SSE2 Support Check,.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.5,.NET Framework Runtime 4.5 Language Pack,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,DirectX Runtime,{FF59CB23-1800-4047-B40C-E20AE7051491},Microsoft Windows Media Format 9.5 Series Runtime,{427F733F-4D6C-45BC-9324-EB743104C321},{ABE2F70B-8D94-44E9-AA04-F0DB35063D62},{A37CDB58-AAE8-0000-8C13-E0F7BACB0D5F},;;{5783F2D7-E005-0409-2102-0060B0CE6BBA},{C403E867-FCF1-432B-BCC1-8FFD40A10A6E},{84A6C8C6-0000-0464-0001-83487CD4C147},{A90DD6F8-60D2-4803-AFF6-796400E73E1B},;{C8125548-F2D5-4059-823F-1F3C5BBD9F19},{EDDEE94B-214D-4B07-9727-A3E46F3E379A},{85735431-6CD3-4B16-BEC8-95332034E53B},{9D589081-AFC2-4932-9071-AC585AC1EA83},;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/11/27:16:02:40 bx1tesse BR00NBKORG10660 Install Autodesk® AutoCAD® Mechanical 2015 Failed Installation aborted, Result=1603
2015/11/27:16:02:40 bx1tesse BR00NBKORG10660 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2015/11/27:16:02:40 bx1tesse BR00NBKORG10660 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Installation aborted, Result=1619
2015/11/27:16:02:40 bx1tesse BR00NBKORG10660 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Installation aborted, Result=1619
2015/11/27:16:02:40 bx1tesse BR00NBKORG10660 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2015/11/27:16:02:40 bx1tesse BR00NBKORG10660 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2015/11/27:16:03:23 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/27:16:19:36 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/27:16:19:36 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/27:16:19:36 bx1tesse BR00NBKORG10660 Current Directory \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img
2015/11/27:16:19:36 bx1tesse BR00NBKORG10660 Launch
2015/11/27:16:19:36 bx1tesse BR00NBKORG10660 CommandLine /qb /I \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\IMAGEM.ini /language en-US
2015/11/27:16:19:36 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI7407.tmp
2015/11/27:16:21:20 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/27:16:20:19 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/27:16:20:19 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/27:16:20:19 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI7407.tmp
2015/11/27:16:20:19 bx1tesse BR00NBKORG10660 Launch
2015/11/27:16:21:22 bx1tesse BR00NBKORG10660 Installing Autodesk® AutoCAD® Mechanical 2015: TRANSFORMS="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\en-us\acadm\acad.mst;\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\acadm\acad-IMAGEM.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;{5783F2D7-E005-0409-2102-0060B0CE6BBA},{C403E867-FCF1-432B-BCC1-8FFD40A10A6E},{84A6C8C6-0000-0464-0001-83487CD4C147},{A90DD6F8-60D2-4803-AFF6-796400E73E1B},;{C8125548-F2D5-4059-823F-1F3C5BBD9F19},{EDDEE94B-214D-4B07-9727-A3E46F3E379A},{85735431-6CD3-4B16-BEC8-95332034E53B},{9D589081-AFC2-4932-9071-AC585AC1EA83},;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/11/27:16:21:29 bx1tesse BR00NBKORG10660 Install Autodesk® AutoCAD® Mechanical 2015 Failed Installation aborted, Result=1603
2015/11/27:16:22:05 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/27:16:59:18 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/27:16:59:18 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/27:16:59:18 bx1tesse BR00NBKORG10660 Current Directory \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img
2015/11/27:16:59:18 bx1tesse BR00NBKORG10660 Launch
2015/11/27:16:59:18 bx1tesse BR00NBKORG10660 CommandLine /qb /I \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\IMAGEM.ini /language en-US
2015/11/27:16:59:18 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AIF517.tmp
2015/11/27:17:02:58 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/27:17:00:35 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/27:17:00:35 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/27:17:00:35 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AIF517.tmp
2015/11/27:17:00:35 bx1tesse BR00NBKORG10660 Launch
2015/11/27:17:03:05 bx1tesse BR00NBKORG10660 Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\bx1tesse\AppData\Local\Temp\_AIF517.tmp\Media.mst"
2015/11/27:17:03:49 bx1tesse BR00NBKORG10660 Install Autodesk® Material Library 2015 Succeeded
2015/11/27:17:03:54 bx1tesse BR00NBKORG10660 Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\bx1tesse\AppData\Local\Temp\_AIF517.tmp\Media.mst"
2015/11/27:17:04:33 bx1tesse BR00NBKORG10660 Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2015/11/27:17:04:34 bx1tesse BR00NBKORG10660 Installing Autodesk® Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS=\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\en-us\Tools\snap\ContentService.mst;C:\Users\bx1tesse\AppData\Local\Temp\_AIF517.tmp\Media.mst ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.5,;;;;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/11/27:17:06:33 bx1tesse BR00NBKORG10660 Install Autodesk® Content Service Succeeded
2015/11/27:17:06:34 bx1tesse BR00NBKORG10660 Installing Autodesk® Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\bx1tesse\AppData\Local\Temp\_AIF517.tmp\Media.mst"
2015/11/27:17:06:49 bx1tesse BR00NBKORG10660 Install Autodesk® Content Service Language Pack Succeeded
2015/11/27:17:06:49 bx1tesse BR00NBKORG10660 Installing Autodesk® AutoCAD® Mechanical 2015: TRANSFORMS="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\en-us\acadm\acad.mst;\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\x64\acadm\acad-IMAGEM.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Block Vista version Check,SSE2 Support Check,.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.5,.NET Framework Runtime 4.5 Language Pack,{FF59CB23-1800-4047-B40C-E20AE7051491},Microsoft Windows Media Format 9.5 Series Runtime,{427F733F-4D6C-45BC-9324-EB743104C321},{ABE2F70B-8D94-44E9-AA04-F0DB35063D62},{A37CDB58-AAE8-0000-8C13-E0F7BACB0D5F},;;{5783F2D7-E005-0409-2102-0060B0CE6BBA},{C403E867-FCF1-432B-BCC1-8FFD40A10A6E},{84A6C8C6-0000-0464-0001-83487CD4C147},{A90DD6F8-60D2-4803-AFF6-796400E73E1B},;{C8125548-F2D5-4059-823F-1F3C5BBD9F19},{EDDEE94B-214D-4B07-9727-A3E46F3E379A},{85735431-6CD3-4B16-BEC8-95332034E53B},{9D589081-AFC2-4932-9071-AC585AC1EA83},;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/11/27:17:06:57 bx1tesse BR00NBKORG10660 Install Autodesk® AutoCAD® Mechanical 2015 Failed Installation aborted, Result=1603
2015/11/27:17:07:42 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/30:15:43:14 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/30:15:43:14 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/30:15:43:14 bx1tesse BR00NBKORG10660 Current Directory \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img
2015/11/30:15:43:14 bx1tesse BR00NBKORG10660 Launch
2015/11/30:15:43:14 bx1tesse BR00NBKORG10660 CommandLine /qb /I \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\IMAGEM.ini /language en-US
2015/11/30:15:43:14 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI222F.tmp
2015/11/30:15:45:21 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/30:15:44:04 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/30:15:44:04 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/30:15:44:04 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI222F.tmp
2015/11/30:15:44:04 bx1tesse BR00NBKORG10660 Launch
2015/11/30:15:45:25 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2015/11/30:15:45:32 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2015/11/30:15:46:21 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/30:15:52:00 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/30:15:52:00 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/30:15:52:00 bx1tesse BR00NBKORG10660 Current Directory \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img
2015/11/30:15:52:00 bx1tesse BR00NBKORG10660 Launch
2015/11/30:15:52:00 bx1tesse BR00NBKORG10660 CommandLine /qb /I \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\IMAGEM.ini /language en-US
2015/11/30:15:52:00 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI2A69.tmp
2015/11/30:15:54:16 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/11/30:15:52:50 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/11/30:15:52:50 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/11/30:15:52:50 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI2A69.tmp
2015/11/30:15:52:50 bx1tesse BR00NBKORG10660 Launch
2015/11/30:15:54:22 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2015/11/30:15:54:31 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2015/11/30:15:56:24 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/12/1:14:19:15 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/12/1:14:19:15 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/12/1:14:19:15 bx1tesse BR00NBKORG10660 Current Directory \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img
2015/12/1:14:19:15 bx1tesse BR00NBKORG10660 Launch
2015/12/1:14:19:15 bx1tesse BR00NBKORG10660 CommandLine /qb /I \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\IMAGEM.ini /language en-US
2015/12/1:14:19:15 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI9545.tmp
2015/12/1:14:21:48 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/12/1:14:20:16 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/12/1:14:20:16 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/12/1:14:20:16 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI9545.tmp
2015/12/1:14:20:16 bx1tesse BR00NBKORG10660 Launch
2015/12/1:14:21:58 bx1tesse BR00NBKORG10660 Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\bx1tesse\AppData\Local\Temp\_AI9545.tmp\Media.mst"
2015/12/1:14:23:01 bx1tesse BR00NBKORG10660 Install Autodesk® Material Library 2015 Succeeded
2015/12/1:14:23:07 bx1tesse BR00NBKORG10660 Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\bx1tesse\AppData\Local\Temp\_AI9545.tmp\Media.mst"
2015/12/1:14:23:48 bx1tesse BR00NBKORG10660 Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2015/12/1:14:23:48 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2015/12/1:14:23:57 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2015/12/1:14:24:47 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/12/1:14:31:58 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/12/1:14:31:58 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/12/1:14:31:58 bx1tesse BR00NBKORG10660 Current Directory \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img
2015/12/1:14:31:58 bx1tesse BR00NBKORG10660 Launch
2015/12/1:14:31:58 bx1tesse BR00NBKORG10660 CommandLine /qb /I \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\IMAGEM.ini /language en-US
2015/12/1:14:31:58 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI3CCA.tmp
2015/12/1:14:34:12 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/12/1:14:32:59 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/12/1:14:32:59 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/12/1:14:32:59 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI3CCA.tmp
2015/12/1:14:32:59 bx1tesse BR00NBKORG10660 Launch
2015/12/1:14:34:15 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2015/12/1:14:34:21 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2015/12/1:14:35:25 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/12/1:14:56:48 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/12/1:14:56:48 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/12/1:14:56:48 bx1tesse BR00NBKORG10660 Current Directory \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img
2015/12/1:14:56:48 bx1tesse BR00NBKORG10660 Launch
2015/12/1:14:56:48 bx1tesse BR00NBKORG10660 CommandLine /qb /I \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\IMAGEM.ini /language en-US
2015/12/1:14:56:48 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AIF8D9.tmp
2015/12/1:14:59:38 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/12/1:14:58:05 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/12/1:14:58:05 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/12/1:14:58:05 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AIF8D9.tmp
2015/12/1:14:58:05 bx1tesse BR00NBKORG10660 Launch
2015/12/1:14:59:43 bx1tesse BR00NBKORG10660 Installing .NET Framework Runtime 4.5: "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\NET\45\wcu\dotNetFramework\dotNetFx45_Full_x86_x64.exe" /q /norestart
2015/12/1:15:04:09 bx1tesse BR00NBKORG10660 Install .NET Framework Runtime 4.5 Succeeded
2015/12/1:15:04:18 bx1tesse BR00NBKORG10660 Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\bx1tesse\AppData\Local\Temp\_AIF8D9.tmp\Media.mst"
2015/12/1:15:05:41 bx1tesse BR00NBKORG10660 Install Autodesk® Material Library 2015 Succeeded
2015/12/1:15:05:50 bx1tesse BR00NBKORG10660 Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\bx1tesse\AppData\Local\Temp\_AIF8D9.tmp\Media.mst"
2015/12/1:15:07:19 bx1tesse BR00NBKORG10660 Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2015/12/1:15:07:19 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2015/12/1:15:07:32 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2015/12/1:15:07:32 bx1tesse BR00NBKORG10660 Rollback .NET Framework Runtime 4.5 Failed Failure is ignored, Result=1619
2015/12/1:15:09:43 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/12/1:15:48:12 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/12/1:15:48:12 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/12/1:15:48:12 bx1tesse BR00NBKORG10660 Current Directory \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img
2015/12/1:15:48:12 bx1tesse BR00NBKORG10660 Launch
2015/12/1:15:48:12 bx1tesse BR00NBKORG10660 CommandLine /qb /I \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\IMAGEM.ini /language en-US
2015/12/1:15:48:12 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI73B.tmp
2015/12/1:15:51:21 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/12/1:15:49:33 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/12/1:15:49:33 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/12/1:15:49:33 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AI73B.tmp
2015/12/1:15:49:33 bx1tesse BR00NBKORG10660 Launch
2015/12/1:15:51:27 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2015/12/1:15:51:40 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2015/12/1:15:53:47 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/12/4:12:13:54 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/12/4:12:13:54 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/12/4:12:13:54 bx1tesse BR00NBKORG10660 Current Directory \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img
2015/12/4:12:13:54 bx1tesse BR00NBKORG10660 Launch
2015/12/4:12:13:54 bx1tesse BR00NBKORG10660 CommandLine /qb /I \\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\IMAGEM.ini /language en-US
2015/12/4:12:13:54 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AIEA47.tmp
2015/12/4:12:15:41 bx1tesse BR00NBKORG10660 === Setup ended ===
2015/12/4:12:14:37 bx1tesse BR00NBKORG10660 === Setup started on BR00NBKORG10660 by bx1tesse ===
2015/12/4:12:14:37 bx1tesse BR00NBKORG10660 Path_Length: 166
2015/12/4:12:14:37 bx1tesse BR00NBKORG10660 Current Directory C:\Users\bx1tesse\AppData\Local\Temp\_AIEA47.tmp
2015/12/4:12:14:37 bx1tesse BR00NBKORG10660 Launch
2015/12/4:12:15:47 bx1tesse BR00NBKORG10660 Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\bx1tesse\AppData\Local\Temp\_AIEA47.tmp\Media.mst"
2015/12/4:12:16:14 bx1tesse BR00NBKORG10660 Install Autodesk® Material Library 2015 Succeeded
2015/12/4:12:16:22 bx1tesse BR00NBKORG10660 Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Factory Design Suite Premium 2015" SETUP_PACKAGECODE={2499F879-2015-450E-B5B0-06336F887BEF} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\bx1tesse\AppData\Local\Temp\_AIEA47.tmp\Media.mst"
2015/12/4:12:17:03 bx1tesse BR00NBKORG10660 Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2015/12/4:12:17:03 bx1tesse BR00NBKORG10660 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "\\br00srvcol004r1\Frontend\Autodesk\Autodesk_FDSP_2015_Enu_Win_64bit_dlm\IMAGEM\Img\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2015/12/4:12:17:13 bx1tesse BR00NBKORG10660 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2015/12/4:12:18:11 bx1tesse BR00NBKORG10660 === Setup ended ===
TravisNave
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
If the prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Thank you for the reply! I tried to reinstall the Suite and it worked this time without any errors.
