Installation & Licensing
4022 Views, 4 Replies
Error 1722
Hello, installing 3DS Max a message appear saying "Error 1722. There is a problem with this Window Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor." any help is appreciated.
4 REPLIES 4
Otto
Hello enrique939 and welcome to the Autodesk community!
It looks like you are seeing a Windows Installer Error Message. The following article(s) should help you resolve the problem:
Windows Installer Error Messages
Errors during AutoCAD software installation
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Darin.Green
Install any and all Window Updates, then disable your antivirus then try the installation again.
If this information was helpful, please consider using the Accept Solution
Mark.Lancaster
@Anonymous
Your installation log file is pointing to a 1603 error.   For the 1722 error start here and see any of those solutions help you out.
Mark Lancaster
This will sovle all install and unstall isssues.... downlowd this sofware from microsoft https://support.microsoft.com/en-us/help/17588/fix-problems-that-block-programs-from-being-installed...
Tags (1)
Administrator Productivity
