Hello, installing 3DS Max a message appear saying "Error 1722. There is a problem with this Window Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor." any help is appreciated.
Install any and all Window Updates, then disable your antivirus then try the installation again.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
Darin Green
@Anonymous
Your installation log file is pointing to a 1603 error. For the 1722 error start here and see any of those solutions help you out.
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous
Mark Lancaster
This will sovle all install and unstall isssues.... downlowd this sofware from microsoft https://support.microsoft.com/en-us/help/17588/fix-problems-that-block-programs-from-being-installed...
