C: drive has over 50GB available
Installation File is downloaded and executed locally.
I have never had problems installing other Autodesk updates on this computer.
Search for a solution yields no useful results
Any suggestions? Thanks.
Solved by jaroslav.pancocha. Go to Solution.
Solved by Thanos603. Go to Solution.
Solved by mdavis22569. Go to Solution.
Solved by DarrenP. Go to Solution.
On Friday March 24, 2023 we released Revit 2023.1.1.1 Update to address Error 101. This Update is a repackaging of the Revit 2023.1.1 Update with the Identity Manager component removed to avoid an Error 101 during installation of the update. All other components provided in this update match the versions provided with Revit 2023.1.1 Update. If you have already installed Revit 2023.1.1 Update, this update will be blocked from installing since due your Revit 2023 installation is already up to date with the latest fixes and enhancements.
you can try logging out & logging back in
fyi the desktop app has been discontinued you will need to upgrade to Autodesk Access to continue to receive updates
DarrenP
