Installation & Licensing
AutoCAD 2024 installation on a MAC
7 REPLIES 7
Message 1 of 8
jrE3X8K
2038 Views, 7 Replies
Setup chases when trying to install AutoCAD 2024 for MAC anyone has a fix ?
Tags (1)
7 REPLIES 7
Message 2 of 8
paullimapa
in reply to: jrE3X8K
Either post on licensing and installation forum or AutoCAD for MAC forum to get better feedback
Paul Li
IT Specialist
@The Office
Message 3 of 8
maxim_k
Hi @jrE3X8K ,
What macOS version do you have on your Mac?
What do you see when it crashes? And alerts?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 8
jrE3X8K
in reply to: maxim_k
Hi Maxim
I am running an IMac (27 incl mod 2010)
With macOS High Sierra version 10.13.6
Kr John
Message 5 of 8
jrsqpr
Hi Maxim
i have an iMac (27 inch, mid 2010)
running macOS High Sierra version 10.13.6
Br John
Message 6 of 8
quinn.zhang
Hi @jrE3X8K @jrsqpr
With macOS High Sierra 10.13, the latest version that you can install is AutoCAD 2021 for Mac.
AutoCAD 2024 for Mac needs Apple MacOS Big Sur v11 or higher Mac OS.
You can refer to the below pages for the system requirements of AutoCAD for Mac.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-requirement...
Message 7 of 8
jrE3X8K
in reply to: quinn.zhang
Thanks for your reply.
I am having a iMac (27 inch, mid 2010 ) running macOS High Sierra version 10.13.6
131 GB free HD
16GB 1333 MHz memory
Have tried to instal AutoCAD 2021 for Mac, and the Setup are still crashing issuing huge reports as:
Process 747
Process Setup (1125)
Be jr
Message 8 of 8
138485
Hi @jrE3X8K
Thanks for reporting this issue.
To research the issue you encountered, could you provide the install logs to us? You can follow this tool to collect all logs into 1 zip file.
After collect logs, you can try below steps to resolve your current issue:
1. uninstall all AutoCAD/LT you installed
2. remove all files in below folders
  • /Library/Application\ Support/Autodesk
  • /Users/<your account>/Library/Application\ Support/Autodesk
  • /tmp
3. reboot your machine
4. download newest 2021 installer(it should be Autodesk_AutoCAD_2021.3_macOS.dmg) and install it again
Please contact us if the install still crash.
Administrator Productivity
