Either post on licensing and installation forum or AutoCAD for MAC forum to get better feedback
Hi @jrE3X8K ,
What macOS version do you have on your Mac?
What do you see when it crashes? And alerts?
Hi Maxim
i have an iMac (27 inch, mid 2010)
running macOS High Sierra version 10.13.6
Br John
With macOS High Sierra 10.13, the latest version that you can install is AutoCAD 2021 for Mac.
AutoCAD 2024 for Mac needs Apple MacOS Big Sur v11 or higher Mac OS.
You can refer to the below pages for the system requirements of AutoCAD for Mac.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-requirement...
Hi @jrE3X8K
Thanks for reporting this issue.
To research the issue you encountered, could you provide the install logs to us? You can follow this tool to collect all logs into 1 zip file.
After collect logs, you can try below steps to resolve your current issue:
1. uninstall all AutoCAD/LT you installed
2. remove all files in below folders
3. reboot your machine
4. download newest 2021 installer(it should be Autodesk_AutoCAD_2021.3_macOS.dmg) and install it again
Please contact us if the install still crash.
