Installation & Licensing
Error 101 installing Revit 2023 .1 Update
24 REPLIES 24
Message 1 of 25
10725 Views, 24 Replies
C: drive has over 50GB available
Installation File is downloaded and executed locally.
I have never had problems installing other Autodesk updates on this computer.
Search for a solution yields no useful results
Any suggestions? Thanks.
24 REPLIES 24
Message 21 of 25
huotger
in reply to: dtiemeyer
On Friday March 24, 2023 we released Revit 2023.1.1.1 Update to address Error 101.  This Update is a repackaging of the Revit 2023.1.1 Update with the Identity Manager component removed to avoid an Error 101 during installation of the update. All other components provided in this update match the versions provided with Revit 2023.1.1 Update. If you have already installed Revit 2023.1.1 Update, this update will be blocked from installing since due your Revit 2023 installation is already up to date with the latest fixes and enhancements.
Gerry Huot
SQA Manager
Message 22 of 25
mbuchanan
in reply to: huotger
Is there a way to make it disappear from the "My updates" list in the Autodesk Desktop App?
Message 23 of 25
DarrenP
in reply to: mbuchanan
you can try logging out & logging back in
fyi the desktop app has been discontinued you will need to upgrade to Autodesk Access to continue to receive updates
https://forums.autodesk.com/t5/autodesk-access-forum/updating-your-autodesk-tools-what-to-know-about...
DarrenP
Message 24 of 25
jbednarz
I am having the same issue installing Formit as well.
Message 25 of 25
peron_0029
in reply to: ToanDN
si funciono eliminado eso
Administrator Productivity
