I am a teacher at a public New Zealand Intermediate School. I teach digital design and work with students to design and create original products using traditional workshop tools, laser cutting, 3D printing and CNC routing.
Our students are aged between 10 and 13 and used 123D up until one month ago. Now we have lost access to a suitable CAD programme because of the vast majority of students are too young to have an autodesk community account.
I have worked with a trial group of students using a start up account and found that they were able to use 360 with a high degree of competency (most found it much easier than 123D).
Is it possible for our school to register for an education account and have this minimum age modified to reflect the age of our students? This is a critical issue for us as a school because we would like for our students to use programmes that are used in at High Schools in our area and in industry should they go on to work in this field.
Regards
Jesse
Solved by Mark.Lancaster. Go to Solution.
@Anonymous
This is a user based support forum. We have no legal standing on changing those rules or guidelines. You will need to contact the Autodesk Educational Support team directly https://www.autodesk.com/education/support/edu-contact-us-form
Mark Lancaster
& Autodesk Services MarketPlace Provider
Are they installing the software onto their own devices? If not then you need to look at site/multi user license.
I have gotten it sorted now (I think). Let me know how to contact you and I will talk you through the process we have used.
Hi @Anonymous,
What's your current issue? This thread is on the older side.
Thank you for your reply. I use Fusion with High School but i'd like to use it with middle school as well. Did you find a way to use it with grade 6 and 7 (Under 13 years old?) without breaching the Autodesk T&Cs?
Thank you,
S.
I am in a similar situation, where do you download the community version from? Can someone provide a link?
