AutoCAD 2021 will not install.
jxd01311
Observer
Observer
jxd01311
Observer
Observer
When attempting to install AutoCAD 2021 the "Install" button and file browser are inaccessible as seen below.
 I have followed the instructions for a clean install to no avail. The above result occurs when using the "Install now" and "Download now" options.
Alfred.NESWADBA
>> I wanted to increase the height of the box
You can't install a software which is already installed (this is what is shown with your dialog)!
If you want to install AutoCAD on a different drive (and you don't have other Autodesk software already installed) then uninstall AutoCAD first (clean uninstall) and then start the new installation.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
