- Mute
- Permalink
- Report
Well, it's that time again. Time to update your Autodesk Network License Manager files to the latest and greatest (Autodesk) version.
Autodesk is providing version 11.13.1.2 for 2017 products.
NOTE: It is required to update to 11.13.1.2 for the product license to work, otherwise you will get a 0.0.0 error.
Just like last year and moving forward, the License Manager files are no longer available for direct download from Flexera. Per their new policy, you must obtain the license manager from your software vendor. You can download the Autodesk Network License Manager files here for both 32-bit and 64-bit versions:
If there are updates to the Autodesk Network License Manager files as the 2017 product line is rolled-out, I will reflect those changes in this thread.
You can update your license file to 2017 versions from your Autodesk Accounts page once your Subscription has been updated.
You can use the online method to activate your license here:
https://register.autodesk.com and from the new Autodesk Accounts page at https://accounts.autodesk.com
Or you can can contact your Value-Added Reseller for assistance. You can locate your VAR here:
http://www.autodesk.com/resellers/locate-a-reseller
To update your license file, you will need to provide your serial number and ethernet ID of the new license server.
For a Quick-Start Guide on configuring the Autodesk License Manager, please see my post for further information:
http://forums.autodesk.com/t5/Installation-Licensing/Quick-Start-Guide-for-Configuring-LMTOOLS/m-p...
Good Luck!
Travis Nave
