Edit: Got it, support reached out and gave us new license keys!
Hey all, we have 2021 AutoDesk products installed on our machines at our schools. We were using the individual license key model to license these installs, which we receive for free as part of being an educational institution. Recently we received an automated email that we may need to re-enter the license key on the installed software. Roughly one month after that email, that was the case.
I went to the machines to try the license key for AutoCAD 2021 that was included in that email. It was the same license key that was already entered. No dice, the key was invalid. I tried the Revit key for Revit 2021. No dice, the key was invalid. This was persistent across multiple machines. I then went to the website and logged in. In one of the views, it gave the same key we already had alongside the download. In another view (viewing all license keys for a given product), it said 2020 and 2021 did not have license keys, and that we needed to contact support to receive a new one.
We have contacted support twice, one time we were "going to hear from [the AutoDesk] education department" with no follow up, and the other time was the same (with follow up to see if this was still an issue, which it was, and was then never resolved). It has been at least a month since the initial contact with support, but we are still having this issue. Just this morning we received an email with the same license key we already had entered, which provided the same result (on a different machine than the first ones we had been testing on).
Any ideas? It is not feasible for us to update to 2022 or 2023 in the near term, as that would take much longer than we have the capacity for currently, and would require the shop teachers to purchase new teaching materials for the updated software. Currently this software is completely unusable due to the licensing, with no option for a trial period (I believe that is how the teacher was getting by before ever contacting us about the license being expired/invalid). Thank you!
Solved by MCUSD25. Go to Solution.
Hey there, thanks for the answer! Unfortunately I'm not seeing anything that sticks out to me in regards to that page.
Below is what it states:
This has been tested, but signing in with our AutoDesk account (which should have the license associated with it) yields the same "no license found" error.
This is not the case, we have always used stand-alone license keys and these stand-alone license keys are still available for 2023 products.
We are using the license key provided to us from AutoDesk via email, specifically for this version of AutoCAD 2021.
Unsure of this, but have been unable to get ahold of support to verify.
Again, unsure of this due to the lack of contact with support, however we should still be eligible for previous versions (up to 3 years back) due to us being a registered educational institution on an education AutoDesk account.
I can confirm this is not the case, as we do not pay for this and receive it for free via the education program.
This is probably what happened, the license key probably expired. Various sources have instructed us to contact support to get a new license key generated. However as mentioned before, this has been fruitless.
Same as above, but trying to sign in with our actual AutoDesk account yields the same issue.
Hey there, yes we have verified all information (including the fact that it is eligible for previous version), and we have tried all solutions listed on that page to no avail.
This is what I get, even when selecting AutoCAD 2021 for the product it only gives me a 2023 license key. I have tried contacting support to get a 2021 license key, and have not had any luck getting a new one. (I did blank out our license key for obvious reasons). Is there another screen you would like me to check?
@rushabhthakkar_910
Hey, yes, we did just follow the steps on that page to no avail. I think the root of the issue is that we are unable to get a new key for 2021, which requires support to provide it to us if I'm not mistaken.
Does it take the Serial Number?
Then you need 001M1
001O1 is for 2023
So the error message part if you can.
Do you have an option to go to the Classic Page?
Yes, the only license key I receive is for 2023 on that page. When I go to download the installer for AutoCAD 2021, it provides me with a key via email that does not work. That key that is provided via email is for product 001M1, which I have confirmed is installed on the affected machines. I believe I need support to provide me a new key for 2021. The AutoDesk virtual agent has said as much, but I have not received a new one. Below is the email I receive, again with license key blocked out:
And here is the classic view, which instructs me to request a new key for 2021. When I do this, I am brought to the AutoDesk Virtual Assistant. This Virtual Assistant is where I've been before to request a new license key for 2021 to no avail. I have also tried their general support chat to no avail either, though that got me further as I was told I would be contacted by AutoDesk Education Support.
Click the get Serial number there .. what happens?
Generally educational is the Current and 2 prior ..
Why the need for so far back for educational version if you don't mind me asking
Hey, yes, as you can see from my previous reply I have tried clicking "Get Serial Number" which takes me to the AutoDesk Virtual Agent. It does not lead to me obtaining a serial number. The reason for 2021 is that is what's already installed, and the teaching materials that our teachers have is for 2021. They do not want to switch up versions of software and teaching materials in the middle of the year, if at all possible to avoid. Thanks!
Follow up on the educational side..
But this is part of it... See what AVA can get you
https://www.autodesk.com/education/support
I believe this is where I got hung up the last time. The AVA tells me I need to finish setting up our education profile to confirm our eligibility using the SheerID we provided. When I follow the link it provides to finish setting up, that page tells me that I already have education access for the next 12 months as you can see from the image below:
This is after I click the link provided by AVA, and click "Get Started" as it shows. Here is the chat log:
At no point am I ever presented with the second screen shown in the AVA, as the account page shows us as having been successfully verified already.
Hey there, when I do this it just takes me back to the page to download software. This time, however, when I download AutoCAD 2021 I do not even receive an email with a license key, like I did before.
I can download the installer for AutoCAD 2021, but it does not give me a license key via email, nor does it show one on this page.
Question, I see this:
Are you signed in under the Wendy account?
And not seeing the 2021( just making sure)
Also, @LeoWarren-EDU
Something you can help with?
Correct, I am signed in under the "Wendy" account. Yesterday and all previous times while trying to download AutoCAD 2021 (or other 2021 products), it would email us like you saw in the screenshot you linked. However, this time I am not getting any email when downloading 2021, after clicking "Get AutoDesk Software" on that previous page.
