Installation & Licensing
AutoCAD self extract is not running.
32 REPLIES 32
Message 1 of 33
92477 Views, 32 Replies
Greetings.
Im trying to install AutoCAD 2018 on my PC (Windows 10, x64, Net Framework 4.6.1, etc...)
I have already tried to deactivate Windows Defender to install the program
I can't run AutoCAD Self Extract.
It opens, however the app suddenly closes without filling anything of the progress bar
I have already tried to solve this issue seeking information at "google".
Please, if anyone knows how to solve this it would be great.
Gian
32 REPLIES 32
Message 21 of 33
I also was facing the same issue in my computer and than I realize its not an issue of the extractor the issue is windows is not able to verify the certificate of the extractor just try to install verisign universal root certificate in trusted root certification authorities it will work for sure...
Message 22 of 33
  • 2017 and earlier products use a different certificate that Windows 7 already contains so the files will extract successfully.
How to Verify if you have the issue on your machine
  • Click 'Start' and type certmgr.msc in the Search Programs and Files field and hit Enter.
  • Expand Certificates and expand Trusted Root Certification Authorities item
  • Select 'Certificates'
  • Look for VeriSign Universal Root Certification Authority
  • If the certificate is available there and is valid, the file extraction and product installation will complete successfully
Solution
The certificate (Root 10) can be downloaded directly from VeriSign's certificate page on their website:
https://www.symantec.com/theme/roots
Message 23 of 33
Here is what helped me, just run Command Prompt as an Administrator and paste the code below.
regsvr32 c:\windows\SysWOW64\wintrust.dll
I discovered this method while solving NVIDIA GeForce Experience problem and it worked.
Message 24 of 33
Just run as administrator. That's all, but why didn't they add  this automatically. That's funny.
Message 25 of 33
Ha ha!... Sorry, No wrong answer. I am admin!
Message 26 of 33
Please mine has been stuck at 395MB out of 5.77GB. how do I solve that please?
Message 27 of 33
Are you sure you have enough space for program?
Message 28 of 33
In my case the installer was split in 6 parts so I had to rename all of them like:
Revit_2021_G1_Win_64bit_dlm_001_006.sfx.exe > r_001_006.exe"
Revit_2021_G1_Win_64bit_dlm_002_006.sfx.exe > r_002_006.exe"
Revit_2021_G1_Win_64bit_dlm_003_006.sfx.exe > r_003_006.exe"
Revit_2021_G1_Win_64bit_dlm_004_006.sfx.exe > r_004_006.exe"
Revit_2021_G1_Win_64bit_dlm_005_006.sfx.exe > r_005_006.exe"
Revit_2021_G1_Win_64bit_dlm_006_006.sfx.exe > r_006_006.exe"
then double click the first part to extract the others.
Message 29 of 33
virgil.p.hartline
AutoCAD_2022_English_Win_64bit_dlm.sfx.exe.  Tried all the above suggestions: used d:\, renamed, etc.  Nothing works on two separate computers (W10).  Downloaded the file from AutoDesk three times..all fail.
Suggestions?
Message 30 of 33
naphtali1033
in reply to: Erense
 That's the problem I have
Message 31 of 33
laomusic_arts
Hi!
here is how I solöved this issue:
_ make sure your OS is updated to latest available version
- make sure you have a Admin account & Read/Write rights
- RMC the file/Run as Administrator
- after extracting, move the folder in question to C:\Autodesk
This is valid for ANY Autodesk !
Hope this helps others!
ALO
Message 32 of 33
kingnithish100
Good morning Sir/Madam,
                          Sir I'm Student Studying At University,I Install Maya Software At The Help Of Educational Access
Tags (1)
Message 33 of 33
@kingnithish100
You're not downloading all parts of the software needed.
Likely a popup blocker is causing it.
Mike Davis
Administrator Productivity
