AutoCad LT 2007 - English installation is aborted.
I am trying to install AutoCad 2007 Lt from the original disk serial number XXX-XXXXXXXX which I own.   I am not downloading from Autodesk.  I purchased every version, from LT windows 95 to the LT 2007.  I need some expert solution to my problem.  I have found AutoCad Lt always a product of absolute genius.  But this installation & activation process reflects poorly on the brilliance of the product.  From 1970 to 1995, I worked the boards, therefore I truely appricate LT.
I tried install as administrator, compadibility mode xp sp2, xp3, and windows 7.  I removed existing copies of Flash.  I read the internet for an answer and tried the many different suggestions.  But I reciece the;
  Autodesk Setup ends with: AutoCad LT 2007 - English installation is aborted; every time.  As I stated in the previous post, I have installed with no problems LT 2007 on my laptop running Windows 2007 64 bit, the same operating system I am trying to install now.  I must assume that compatibality is not an issue.  I am nearly ready to install from floppy disk autocade lt 95 on an old laptop running windows 95.
Please check C:\Users\........\AutoCAD LT 2007 Setup.log for details.
The Setup Log reads as follows:
2015/11/14:16:18:36 James E Frizzell POWERSPED === Installation started on POWERSPED by James E Frizzell ===
2015/11/14:16:18:38 James E Frizzell POWERSPED Install MSI Runtime 3.1 Skipped Windows Installer upgrade is not required. System Version = 5.0.7601.18896
2015/11/14:16:18:38 James E Frizzell POWERSPED Install .NET Framework Runtime 2.0 Skipped .NET Framework Runtime upgrade is not required. System Version = 2.0.50727.0
2015/11/14:16:18:38 James E Frizzell POWERSPED Install .NET Framework Runtime 2.0 Language Pack Skipped Installation not required
2015/11/14:16:18:54 James E Frizzell POWERSPED Install Autodesk DWF Viewer Succeeded Command = "D:\Bin\AcltFEUI\support\aev\DWFViewerSetup.exe" /u2 /q2 /b0
2015/11/14:16:18:58 James E Frizzell POWERSPED Install Flash Failed Failure is ignored, Result=1
2015/11/14:16:20:44 James E Frizzell POWERSPED Install AutoCAD LT 2007 Failed Installation aborted, Result=1639
2015/11/14:16:20:44 James E Frizzell POWERSPED === Installation ended ===
Also this information appears as the installation fails.  I find it useless but maybe someone can make use of it.
Windows ® Installer. V 5.0.7601.18896
msiexec /Option <Required Parameter> [Optional Parameter]
Install Options
</package | /i> <Product.msi>
Installs or configures a product
/a <Product.msi>
Administrative install - Installs a product on the network
/j<u|m> <Product.msi> [/t <Transform List>] [/g <Language ID>]
Advertises a product - m to all users, u to current user
</uninstall | /x> <Product.msi | ProductCode>
Uninstalls the product
Display Options
/quiet
Quiet mode, no user interaction
/passive
Unattended mode - progress bar only
/q[n|b|r|f]
Sets user interface level
n - No UI
b - Basic UI
r - Reduced UI
f - Full UI (default)
/help
Help information
Restart Options
/norestart
Do not restart after the installation is complete
/promptrestart
Prompts the user for restart if necessary
/forcerestart
Always restart the computer after installation
Logging Options
/l[i|w|e|a|r|u|c|m|o|p|v|x|+|!|*] <LogFile>
i - Status messages
w - Nonfatal warnings
e - All error messages
a - Start up of actions
r - Action-specific records
u - User requests
c - Initial UI parameters
m - Out-of-memory or fatal exit information
o - Out-of-disk-space messages
p - Terminal properties
v - Verbose output
x - Extra debugging information
+ - Append to existing log file
! - Flush each line to the log
* - Log all information, except for v and x options
/log <LogFile>
Equivalent of /l* <LogFile>
Update Options
/update <Update1.msp>[;Update2.msp]
Applies update(s)
/uninstall <PatchCodeGuid>[;Update2.msp] /package <Product.msi | ProductCode>
Remove update(s) for a product
Repair Options
/f[p|e|c|m|s|o|d|a|u|v] <Product.msi | ProductCode>
Repairs a product
p - only if file is missing
o - if file is missing or an older version is installed (default)
e - if file is missing or an equal or older version is installed
d - if file is missing or a different version is installed
c - if file is missing or checksum does not match the calculated value
a - forces all files to be reinstalled
u - all required user-specific registry entries (default)
m - all required computer-specific registry entries (default)
s - all existing shortcuts (default)
v - runs from source and recaches local package
Setting Public Properties
[PROPERTY=PropertyValue]
Consult the Windows ® Installer SDK for additional documentation on the
command line syntax.
Copyright © Microsoft Corporation. All rights reserved.
Portions of this software are based in part on the work of the Independent JPEG Group.2015/11/14:16:18:36 James E Frizzell POWERSPED === Installation started on POWERSPED by James E Frizzell ===
please advise
 Again thank you
James E Frizzell
BJ.C
Hello @Anonymous
Your initial comment about your issue suggested you were trying to install AutoCAD LT 2007 on a Windows 8, 8.1, or 10 system. (compatibility mode for Windows 7 would suggest this) That's unlikely going to happen.  I would suggest installing this on a system with Windows XP.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/System...
Thank you for taking part in our community forum!
Kind Regards,
BJ.C
Technical Support Specialist
I have AutoCad Lt 2007 installed on my laptop running tip top on Windows 7 Professional, as stated before.  So, is there a difference in compadability for Lt 2007 laptop verses desktop.   I already have Virtual PC XP mode on my desktop and having trouble activating AutoCad Lt 2006 on it.  Autodesk informed me via internet that serial number was invalid, therefore I am in the process of getting activation code via United States Post Office as directed by Autodesk.
I am installing Lt 2006 and Lt 2007 from original hard disk which I own and regestered at the time of initial installation.  It is frustrating having paid for the seat and not being able to ride.
I perfer if at all possible install Lt 2007 directly in Windows 2007.  It seams that the installation fails due to Macromedia Flash failure.  Can this issue be addressed?
TravisNave
You can update your Flash, or hit ignore a dozen times if presented with that error.  Otherwise, 2007 is not supported on Windows 7.  The underlaying code and activation is not compatible.  You need to run 2010 or later.  Beyond that, anything before 2013 is officially retired anyway.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Installed Microsoft Virtual PC XP Mode and Autocad LT 2007 installed not problem on my Winsows 7 Professional operating system.
James E Frizzell
You don’t have to use Longbow software or setup vitual.
Land desktop companion 2009 is the best solution on win 64 bit.
Every funtions, display, commands in land desktop civil design 2007 is all in LDT 2009
You can see and download here!
https://www.youtube.com/watch?v=9xUoq0SdwBg
Mark.Lancaster
@Anonymous
Yeah this may be possible...  But if they don't own the product then how they going to use it and activate it?  Smiley Wink
Mark Lancaster
