When I start the application, appears the autocad loading window and after a few seconds it crases.
I tried to uninstall and reinstall the program but nothing changed.
Do you know solution to solve problem??
Thank You
Filippo Romani
Solved by filippo.romani. Go to Solution.
Solved by mdavis22569. Go to Solution.
Can you help me with the following questions:
Are you getting an Error message?
What OS?
Are all of the updates installed?
What video card and driver do you have installed?
The problem is that I'm not getting any Error message.
I have Winsows 10 Pro 20H2 and I installed the autocad update 2021.1.
Driver of Nvidia quadro RTX 3000: 27.21.14.5266
Driver of Intel UHD Graphics 630: 27.20.100.8280
If it can help my pc is a Dell precision 7540 with i9-9980Hk
Thank You
Filippo Romani
So I would make sure you're using the following video card driver:
NVIDIA Quadro RTX 3000 | Turing | 8226 | Workstation | NVIDIA | Quadro Desktop/Quadro Notebook 441.12 | Download |
This is the certified driver for AutoCAD 2021 ...
Then do a Right Click on the AutoCAD icon and click the Run as Admin ..
Thank you mdavis22569
it was a driver problem, now autocad work perfectly fine!!
I've installed a similar one for the dell website (26.21.14.4283, A05)
Thank you again,
Filippo Romani
