Installation & Licensing
AutoCAD 2015 cannot install
6 REPLIES 6
778 Views, 6 Replies
Hi there
  I can't reinstall AutoCAD 2015 after uninstalling it due to problems. Can someone help?
6 REPLIES 6
Mark.Lancaster
@Anonymous
Welcome to the community...
See this article and I would also recommend for you to perform a clean uninstall per these instructions.  Just make sure to adjust settings if you have other Autodesk products already installed/working on your machine.
Then download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it.  Posting info: Sometimes installation log files contain personal information such as your serial #.  Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
in reply to: Mark.Lancaster
  I cannot uninstall Autodesk Content Service and Autodesk Desktop App. When I try to uninstall Autodesk Content Service, a pop up says 'Failed to get Allied products' and I would be unable to uninstall it. As for Autodesk Desktop App, a pop up says, 'Autodesk Desktop App is still running on this computer. All instances must be quit prior to uninstall.'
  If I am unable to uninstall these two Autodesk products, I might not be able to install other Autodesk products as the articles you sent stated to get rid of all Autodesk apps.
Mark.Lancaster
@Anonymous
You need to go into WIndows/Services and stop both of these services.
Then continue with the uninstall steps.  If you are unable to uninstall either one of these, don't worry about it.
Mark Lancaster
  I followed the steps but nothing worked. Plus, I don't know where to find the ProductInformation.pit file on my comp. Maybe that is why I can't reinstall AutoCAD.
Mark.Lancaster
@Anonymous
C:\Programdata is a hidden folder.  Are you viewing hidden files and folders?
Mark Lancaster
Nope, I don't even know where to find hidden files/folders, unfortunately. 😞
I don't know if I can ever reinstall AutoCAD 2015 on my PC again, but I have an old Mac with AutoCAD 2015 on it.
Administrator Productivity
