Hello guys;
When I install the AutoCAD Electrical 2016 on my PC (Windows 10 Build 10041) i got this error:
Install AutoCAD Electrical 2016 Core Failed Installation aborted, Result=1603
I have AutoCad 2016 installed on a 32-bit Windows 10 installation. No installation isssues. No additional requirements.
Bonjour,
je souhaite installer Autocad 2016 sur mon ordinateur en tant qu'etudiant nous avons 3an gratuit.
le probleme et que sur monordinateur je suis sous Windows 10 et je n'arrive pas a l'installer et je pense que c'est acause de cela.
pouvais me dire comment proceder pour reussir a l'installer sur mon ordinateur SVP
Cordialement.
I tried to install Autocad 2016 on Windows 10, but failed.
@Anonymous
Welcome to the community..
That user is referring to the program that is in the attached ZIP file.. I don't know what it does but I would caution you in programs that are accessing the registry.. Something goes wrong and corrupts your registry then you could "break" your computer..
What issues are you actually having? We maybe able to assist you without the need to use this program.
Mark Lancaster
& Autodesk Services MarketPlace Provider
I'm having trouble installing 22016 auto cad on new windows 10 system. Can any one help me?
error message below.
@TravisNave wrote:If it still errors for 4.5, you might have to remove it altogether from the setup.ini
2017/1/19:19:40:43 steven DESKTOP-CRHKF2B === Setup started on DESKTOP-CRHKF2B by steven ===
2017/1/19:19:40:43 steven DESKTOP-CRHKF2B Path_Length: 154
2017/1/19:19:40:43 steven DESKTOP-CRHKF2B Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/1/19:19:40:43 steven DESKTOP-CRHKF2B Launch
2017/1/19:19:40:43 steven DESKTOP-CRHKF2B CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/1/19:19:40:43 steven DESKTOP-CRHKF2B Current Directory C:\Users\steven\AppData\Local\Temp\_AI8B0A.tmp
2017/1/19:19:47:52 steven DESKTOP-CRHKF2B === Setup ended ===
2017/1/19:19:40:45 steven DESKTOP-CRHKF2B === Setup started on DESKTOP-CRHKF2B by steven ===
2017/1/19:19:40:45 steven DESKTOP-CRHKF2B Path_Length: 154
2017/1/19:19:40:45 steven DESKTOP-CRHKF2B Current Directory C:\Users\steven\AppData\Local\Temp\_AI8B0A.tmp
2017/1/19:19:40:45 steven DESKTOP-CRHKF2B Launch
2017/1/19:19:41:29 steven DESKTOP-CRHKF2B Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/1/19:19:41:30 steven DESKTOP-CRHKF2B Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/1/19:19:41:30 steven DESKTOP-CRHKF2B Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x64...
2017/1/19:19:41:53 steven DESKTOP-CRHKF2B Download Aborted SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x64...
2017/1/19:19:41:53 steven DESKTOP-CRHKF2B Error downloading. Please Install Now again from the Autodesk website. 2017/1/19:19:47:53 steven DESKTOP-CRHKF2B === Setup ended ===
2017/1/19:19:50:34 steven DESKTOP-CRHKF2B === Setup started on DESKTOP-CRHKF2B by steven ===
2017/1/19:19:50:34 steven DESKTOP-CRHKF2B Path_Length: 154
2017/1/19:19:50:34 steven DESKTOP-CRHKF2B Current Directory C:\Users\steven\AppData\Local\Temp\_AI85EE.tmp
2017/1/19:19:50:34 steven DESKTOP-CRHKF2B Launch
2017/1/19:19:50:35 steven DESKTOP-CRHKF2B Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/1/19:19:50:36 steven DESKTOP-CRHKF2B Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x64...
2017/1/19:19:50:59 steven DESKTOP-CRHKF2B Download Aborted SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x64...
2017/1/19:19:50:59 steven DESKTOP-CRHKF2B Error downloading. Please Install Now again from the Autodesk website. 2017/1/19:19:51:06 steven DESKTOP-CRHKF2B === Setup ended ===
2017/1/19:19:50:32 steven DESKTOP-CRHKF2B === Setup started on DESKTOP-CRHKF2B by steven ===
2017/1/19:19:50:32 steven DESKTOP-CRHKF2B Path_Length: 154
2017/1/19:19:50:32 steven DESKTOP-CRHKF2B Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/1/19:19:50:32 steven DESKTOP-CRHKF2B Launch
2017/1/19:19:50:32 steven DESKTOP-CRHKF2B CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/1/19:19:50:32 steven DESKTOP-CRHKF2B Current Directory C:\Users\steven\AppData\Local\Temp\_AI85EE.tmp
2017/1/19:19:52:47 steven DESKTOP-CRHKF2B === Setup started on DESKTOP-CRHKF2B by steven ===
2017/1/19:19:52:47 steven DESKTOP-CRHKF2B Path_Length: 154
2017/1/19:19:52:47 steven DESKTOP-CRHKF2B Current Directory C:\Users\steven\AppData\Local\Temp\_AI8DE3.tmp
2017/1/19:19:52:47 steven DESKTOP-CRHKF2B Launch
2017/1/19:19:52:47 steven DESKTOP-CRHKF2B Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUPMARK...
2017/1/19:19:52:48 steven DESKTOP-CRHKF2B Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x64...
2017/1/19:19:53:11 steven DESKTOP-CRHKF2B Download Aborted SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{67A610D2-8F2A-440B-A3EE-7213295D082A}/SETUP_x64...
2017/1/19:19:53:11 steven DESKTOP-CRHKF2B Error downloading. Please Install Now again from the Autodesk website. 2017/1/19:19:53:15 steven DESKTOP-CRHKF2B === Setup ended ===
2017/1/19:19:52:45 steven DESKTOP-CRHKF2B === Setup started on DESKTOP-CRHKF2B by steven ===
2017/1/19:19:52:45 steven DESKTOP-CRHKF2B Path_Length: 154
2017/1/19:19:52:45 steven DESKTOP-CRHKF2B Current Directory C:\Autodesk\AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us
2017/1/19:19:52:45 steven DESKTOP-CRHKF2B Launch
2017/1/19:19:52:45 steven DESKTOP-CRHKF2B CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_32_64bit_Trial_wi_en-us..."
2017/1/19:19:52:45 steven DESKTOP-CRHKF2B Current Directory C:\Users\steven\AppData\Local\Temp\_AI8DE3.tmp
2017/1/19:19:53:16 steven DESKTOP-CRHKF2B === Setup ended ===
2017/1/19:19:56:07 steven DESKTOP-CRHKF2B === Setup started on DESKTOP-CRHKF2B by steven ===
2017/1/19:19:56:07 steven DESKTOP-CRHKF2B Path_Length: 154
@Anonymous
Well your installation is simply failing due to the method (web installer) you're using. This method is unreliable and shouldn't be used.
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
@Anonymous
Not sure why you provided your installation log again.. I've already told you that its failing due to the method you're using.. Just follow my instructions using the Autodesk Virtual Agent (because I can tell by the log file you haven't done that).
Mark Lancaster
