I am getting an error when trying to install max 2017 on windows 7. It says 3dsmax.exe is running, but it is not and I can't proceed with the install. Does anyone have any advice here?
Lyle
I should add that I have gone to the task manager and the processes tab and can see that 3dsmax.exe is running under the SYSTEM user name. When i try to end the process it immediately reopens and I can't proceed with the max 2017 install. (I also have 3ds max 2015 installed and I want to keep it installed for the time being)
Lyle
@Anonymous
Welcome to the community...
Have you rebooted your machine? Then recheck the task manager? Is 3DS Max still there?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Yes I have tried that twice now and it appears in the task manager after rebooting. Should 3dsmax.exe always be running in the background as a SYSTEM user? And is there a way to end the process and prevent it from restarting immediately afterwards?
Lyle
I found the problem! It was vrayspawner running in the background and it is installing now. This case is closed!
Thank you,
Lyle
