Installation & Licensing
3ds max 2017 install problem - saying 3dsmax.exe is running
5 REPLIES 5
2704 Views, 5 Replies
I am getting an error when trying to install max 2017 on windows 7. It says 3dsmax.exe is running, but it is not and I can't proceed with the install. Does anyone have any advice here?
Lyle
5 REPLIES 5
Otto
Hello lylecarroll3d and welcome to the Autodesk community!
It looks like you need to find out more about downloading or re-downloading software, or are having issues that may be resolved by re-downloading.
For Windows users, before downloading products on Windows 10, please check that the product is compatible.
For general information about downloading or re-downloading (including eligibility), Community members with similar questions found the following article(s) useful:
Download Finder
Previous Versions of Autodesk Software
Download Methods
Find Your Eligibility for Previous Versions of Autodesk Software
Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. Community members with similar issues found the following article(s) useful:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
I should add that I have gone to the task manager and the processes tab and can see that 3dsmax.exe is running under the SYSTEM user name. When i try to end the process it immediately reopens and I can't proceed with the max 2017 install. (I also have 3ds max 2015 installed and I want to keep it installed for the time being)
Lyle
Mark.Lancaster
@Anonymous
Welcome to the community...
Have you rebooted your machine?  Then recheck the task manager?  Is 3DS Max still there?
Mark Lancaster
in reply to: Mark.Lancaster
Yes I have tried that twice now and it appears in the task manager after rebooting. Should 3dsmax.exe always be running in the background as a SYSTEM user? And is there a way to end the process and prevent it from restarting immediately afterwards?
Lyle
I found the problem! It was vrayspawner running in the background and it is installing now. This case is closed!
Thank you,
Lyle
Administrator Productivity
