Unable to install on Windows Server 2019
noamgat8JLC7
Message 1 of 12
noamgat8JLC7
I am trying to install Autodesk Robot on a Windows Server 2019 machine. Midway through the installation (roughly 30%), the progress bar starts moving down back to zero, then I get an "Error 1624 failure".
I tried doing it again on a fresh installation (Install windows server 2019, install autodesk desktop app, install RSAPRO 2022), with the same result.
Revit 2021 / 2022 install cleanly in the same method.
What can I do?
Replies (11)
Message 2 of 12
natasha.l
Hello @noamgat8JLC7
Please review the “Install Failed - Error 1624” when installing Autodesk products.
Please follow these steps:
  1. Conduct a Clean Uninstall of the previous installation & use the Microsoft Troubleshooter Tool to complete it
  2. Reboot the computer, make sure apps are not auto running in the background
  3. Log in as Administrator (check your permissions, full control) or create a new profile
  4. Apply the latest Autodesk Licensing Service Update & Single Sign On Component (2020 & up).
  5. Use the Browser Download Method in your Autodesk Account or via the AVA | Autodesk Virtual Agent (download all the parts)
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 3 of 12
noamgat8JLC7
Thanks for the response. We have tried all of those steps, including formatting the computer and installing it from scratch, and we still get the same error.
Is there an installation log stored somewhere? What can we do?
Message 4 of 12
pendean
Community Legend
Community Legend
Your IT folks know to look in each PC's user login person's TEMP folder for those log files: work with them. If that is you, well... .
In File Manager in Windows for example, the folder name in the address bar to type is %TEMP%
Message 5 of 12
m_latz
We need the msi log files to check.
Just a question, can you create an "online custom deployment" for Autodesk Robot and try to install through the deployment ? Because there the installation is a little bit different and if my guess is correct it could work. If not post the msi log files here.
regards
Markus
Message 6 of 12
mdavis22569
@noamgat8JLC7
I didn't think you could install Robot or Revit on the Server itself .. Thought it had to be W10 or W7
System Requirements for Autodesk Robot Structural Analysis Professional 2019
Operating system
Microsoft® Windows® 10 (64-bit edition)
  • Microsoft Windows 10 Home
  • Microsoft Windows 10 Pro
  • Microsoft Windows 10 Enterprise
  • Microsoft Windows 10 Education
  • Microsoft Windows 10 Enterprise LTSB
  • Microsoft Windows 10 Pro Education
Microsoft Windows 8.1 (64-bit edition)
  • Microsoft Windows 8.1
  • Microsoft Windows 8.1 Pro
  • Microsoft Windows 8.1 Enterprise
Microsoft Windows 7 (64-bit edition)
  • Microsoft Windows 7 SP1
  • Microsoft Windows 7 SP1 Professional
  • Microsoft Windows 7 SP1 Enterprise
  • Microsoft Windows 7 SP1 Ultimate
Revit SERVER will install on Server 2019, but I didn't think Robot could
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/CloudHelp/cloudhelp/2021/ENU/Revit...
Mike Davis
Message 7 of 12
Tiana_Y
Hi @noamgat8JLC7 - I'm just checking in to see if you need more help with this. Did the suggestions that were provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Best,
Tiana.D
Community Program Manager
Contact Autodesk Support
Message 8 of 12
noamgat8JLC7
Hi!
We have not resolved the issue yet. Attaching a zip file with the install logs. If anyone can take a look and advise what to do next, we would appreciate it a lot.
Message 9 of 12
mdavis22569
@noamgat8JLC7
Operating system
Mike Davis
Message 10 of 12
m_latz
@noamgat8JLC7 ,
thank you for your log files.
Just took a look and it looks like the installer had a problem with the access of the transformation file.
I have to check this on a virtual server ...
regards
Markus
Message 11 of 12
m_latz
Okay I tried and run into the same error. I solved the problem with the modification of the file "C:\Autodesk\Robot_Structural_Analysis_Professional_2022_Multilingual_Win_64bit_dlm\x64\RSA\pkg.RSAPRO.xml".
I added the following variable to the TRANSFORMS parameter:
"TRANSFORMS=%INSTALL_SOURCE%\x64\%LANGUAGE_CODE%\RSA\RSA.mst"
regards
Markus
Message 12 of 12
noamgat8JLC7
@m_latz- you are a wizard. It worked! Thank you so much!
