T-spline license
T-spline license
T-spline license
Hello,  I own a (pre july 2013) license for T-splines plug-in for Rhino 5.  I had to re-install it on a newer computer but license fails. I also tried the T-splines download version from Autodesk but it requires a different type of licensing. I also own Fusion 360 but for my type of work, Rhino and T-slplines are more convenient. Is there any way Autodesk could generate a new license for T-splines to replace my old one? Thanks, Julien
TravisNave
Licensing for this product ended for your version on July 19, 2018.  I am not sure you can get a license for this anymore.  All you can do is ask [email protected]
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Thanks! Autodesk support actually contacted me and installed my license. Very happy now!
